Quick cylinder qeustion about cleaning
Correct me if I am wrong Indawoods, but I think Indawoods is saying to check the ring end gap before assembly. That specification and technique is in the service manual.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yup! :mrgreen:
canyncarvr
Post by canyncarvr »
Below is a Pro-X piston size chart for a KDX200. The same sort of thing exists for the 220.
The difference from one alpha to the next is .01mm, or slightly less than 1/2 of one thousandth of an inch...0004".
You're putting in a Wiseco. They don't size their pistons like that. You don't HAVE a choice in your case. I'm sure all the Wiseco's vary in size as the Pro-X pistons do (OK..ART or whatever you wish to call them), but they do not designate them as such.
You're not going to have a lot of luck measuring that small a value anyway.
As Inda says, the Wiseco setup for the 220 is a kit. Use the rings that come with the kit.
The 'A,B,C,D' (in your case 'B') on the Kaw cylinder (and the piston crown..see that, too?) denote which sized cylinder you have.
