Anyone ever do anything to their rear shock??
skipro3
Post by skipro3 »
Jason should know if the shock could be shortened without looseing any travel length. But the reservoir tank is larger on the KX, so as the shock compresses, clearance may be an issue too.
Jerry
Ryan
Post by Ryan »
someone buy one and tell me if it fits :grin:
Has thanked: 190 times
skipro3, you may be able to take the KX spring off, set the rebound to full out counterclockwise, then see if it will fit while moving it through a range of motion.
From my experience with KX shocks, the shaft travel is definitely longer than a KDX shock, so one would have to have its travel shortened to keep the travel the same amount as stock. Well, unless of course you need 15" of travel in the back, with the back end sticking up real high. Great for uphills, not so great for downhills. :lol:
Ryan
Post by Ryan »
does anyone know if i need tools to clean this shock myself?? If so how much do they cost, thanks
Do you mean the outside or the inside?
Ryan
Post by Ryan »
pretty much both, i want to be able to take the whole thing apart.
KanuckKDX
Post by KanuckKDX »
kdx220freak wrote:does anyone know if i need tools to clean this shock myself?? If so how much do they cost, thanks
1. Yes, you need tools.
2. $10 - $200.
:razz: Forgive my sarcasm. I couldn't resist.
Edit:
Okay, I'm over it now.
You shouldn't need any special tools. The hardest part was getting the springy rings holding the bladder part together. This is where I needed expereince I didn't have and bailed out to a pro. He used some pretty hard hits to get to those rings. He worked. I watched and gave (unheeded) advice. Start and proceed carefully. Ask here if you get stuck. Jason seems to be the only pro online here who gets paid to do this. I would pay for his advice by letting him do the job. $55 is fair. the rest of us can give advice for free. You'll get what you pay for usually.
KanuckKDX
'01 YZ426F son's
'02 XR400 still for sale
'04 KTM 450exc it's all about the e-start
KDXer
Post by KDXer »
Nyuk nyuk nyuk !!! :lol:
