Speedometer cable guide/bracket on the front fender
JasonK94Z
Post by JasonK94Z »
I went to install a new front fender the other day, and noticed there is a cable guide that is riveted to the factory front fender on the right side. I am attempting to install a KX front fender right now. Do I really need to mount that cable guide (bracket) to the new fender?
2002 KDX 220R
2003 KLR 650
koshari
Re: Speedometer cable guide/bracket on the front fender
Post by koshari »
Will you be using the speedo cable?
Just drill out the rivets on the old one and rivet the guide to the new fender. Takes < 10 min.
Only need it if you run the factory odometer. If not don't worry about it. If so^^^what Nick said.
Use washers on the backside of the fender also to keep the rivets from pulling through the soft plastic.
JasonK94Z
Post by JasonK94Z »
Thanks everyone! I'm still using the odometer so I'll get some rivets.
2002 KDX 220R
2003 KLR 650
