I have seen a lot worse.....nearly all 2 stroke pistons will eventually have some type of scoring on the intake side, it just depends on the age of the piston & how clean & oiled you keep your air filter ( here`s the secret ! )
By the look of it you can see some of the coating has worn off the reed intake, this may indicate that dirt has at some point made its way in to the motor thus scoring the piston, you may also find some scoring on the exhaust side too.
