Needle Bearings
NewKDX
Needle Bearings
Post by NewKDX »
Ok so I finally go my shock serviced and put back in the bike. But today while I was in the garage I found a small needle bearing on the ground can a bearing just fall out when you are removing the shock and putting i back in the bike? Confused here because the bearings are fairly new in the linkage.
kx200
Needle Bearings
Post by kx200 »
grease is all that hold them in place
Has thanked: 5 times
Re: Needle Bearings
Yep, gotta take it back apart. :sad:
ICRage42
Needle Bearings
Post by ICRage42 »
be sure to check them all to make sure no gaps. You could of dropped more then one. Yea just grease usually holds em in place.
Gotanubike
Needle Bearings
Post by Gotanubike »
You can prevent that by putting the sleeve and bolt back in the linkage until you put the shock back in.
if you need to buy a new bearing might I suggest pivot works, they are $3.49
http://www.pivotworks.com/ProductInfo.a ... m_id=52099
1990 KDX200
