Maxima 927 Picture " wow"
C George
Post by C George »
Here is the cylinder head that I just pulled off my 05 KDX-220.
I bought the bike " brand new " in 2009 and it's never been apart.
I've run Maxima 927 for it's entire life and am just amazed at how
clean this cylinder head is. :supz:
The ONLY reason this engine is coming apart is to replace the stock
piston with a Wiseco forged one. :grin:
05 KDX-220R / 06 KDX-225R / Maxima 927 / Millenium Tech / Ron Black / PC , FMF / Many 220 engine mods / 40 + yrs. of riding dirt bikes 🀟🀟
hbgod
Re: Maxima 927 Picture " wow"
Post by hbgod »
Castor 927 is where its at man. thats all i use in all my 2 strokes.
C George
Post by C George »
I'll clean up the kips system while it's apart but that too is very clean and
moves easy. Actually I forgot that I took took one tension washer out to
make it slightly tighter. A little Shop Solv and let's go.
Has thanked: 66 times
Been thanked: 20 times
Thank you for the picture. I use it some.
C George
Post by C George »
I'll probably send the head out to Ron Black before putting it back together.
Four months untill spring here :(
Hmm. Groundhog said six weeks. :razz:
C George
Post by C George »
hbgod wrote:Castor 927 is where its at man. thats all i use in all my 2 strokes.
I pulled the kips linkage cover off and there was virtually zero carbon or sludge build up.
Wiped the cover and bolted it back on. :grin:
Gotta love that smell ,,, something a modern four stroke rider will never experience.
diymirage
Post by diymirage »
Jason wrote:Hmm. Groundhog said six weeks. :razz:
-1997 KDX 220 project bike
Yeah, good frosting of snow here, closing schools today, threatening tomorrow and Thursday, just stupid..
Down here an inch or two = standstill
diymirage
Post by diymirage »
anything under a foot is considered a dusting here
C George
Post by C George »
OE Piston after five years of running Maxima 927. :grin:
Factory Knurls can be felt on the entire piston surface.
I actually sold it on E-bay ,,,,, somebody will get a lot more use out of it.
C George
Post by C George »
I just got my 220 head back today from RB . What a beautifull job !
Just no comparison to the local job I had done to the 200.
Turn around time was great as I mailed it out the 10th and got it back on the 18th. :grin:
fuzzy
Post by fuzzy »
Curious, how much time do you spend 'lugging' or off-idle? As a percentage of your service?
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
C George
Post by C George »
fuzzy wrote:Curious, how much time do you spend 'lugging' or off-idle? As a percentage of your service?
I guess I don't follow your question completely but to answer what I believe your asking is this bike is aggressively
trail ridden in usually 3rd / 4th gear. 2nd in some tight stuff.
Why ? This bike only idles to warm up and lugs very seldom. Do I rev it out to 8000 on every shift ? NO :?
Does it look like it's running rich and has fuel stains ?? It's jetted good with a 35mm ,, just has the typical 220 sputter.
I'm crossing my fingers that with all the changes this winter , it will sputter less. :grin:
C George
Post by C George »
Great oil and custom blended fuel !!!! The only thing these bikes ever see.
fuzzy
Post by fuzzy »
You understood correctly. It's been my experience that castor blends will not look like this unless ridden a bit aggressively. A LOT aggressively if the jetting isn't right. Castor blends, if not pure castor, are the **** for WOT all the time applications. Looks like it works perfect for you, but also the reason when the 'oil question of the month' comes up I always recommend a full synthetic (non-'racing' even) for a trail bike. The superior film strength of the castor is mostly beneficial under extreme abuse. Castor certainly smells the best :mrgreen: If you can keep it running clean like this it would be hard to argue that castor isn't the best oil to use. Your engine looks nearly perfect inside!
