Case splitting.
- Has thanked: 13 times
- Been thanked: 21 times
Case splitting.
Well, the case splitter is an absolute necessity unless you want to trash the case halves. However, you don't have to buy the crank puller/installer. Plenty of people have put bottom ends together without one. I did mine without one.
What I did was the freeze the crank (for at least four hours) and drop it into the oven heated (200 degrees F- 20 minutes) right case half method. Smooth as butter! I let it all sit to come to room temp before going any further. Then I laid on a bead of Yamabond and then dropped on the oven heated left case half. Unfortunately, I couldn't work fast enough to get it all together before the bearings and case half gripped onto one another but did get it about half way on. I made my own poor mans crank puller (some extra trans gears and washers) and used the flywheel nut to cinch down the case halves. You could do the same thing with a small piece of pipe cut to the right length and some thick flat washers. If you have a Dremel you can make the pipe fit the case even better. Look at the post above with the crank tool in it and you can figure out how it works.
GKBO
Case splitting.
I was despairing of even getting the 86 any farther yesterday so why send the $$ on tools to fix the dead engine if there's no carb?With at least the possibility I can get her up and going I 'm feeling better about it.Going to see if I can borrow a splitter from someone on my local bike forum to.
86 KDX200 thread http://kdxrider.net/forums/viewtopic.php?f=119&t=13295
My other bikes:
85GS750EF,Old Yeller http://www.thegsresources.com/_forum/sh ... p?t=161477 and http://www.thegsresources.com/_forum/sh ... p?t=175660
78 GS1000 Red Skunk http://www.thegsresources.com/_forum/sh ... p?t=176156
Street bike rider playing in the dirt.
My other bikes:
GKBO
Case splitting.
I bought this harmonic remover to get the flywheel off,If I can line it up with 3 or 4 case bolts would it work as a case splitter?Edit:Never mind,I will not line up
My other bikes:
My other bikes:
GKBO
Case splitting.
Found something interesting in the Clymer manual http://books.google.ca/books?id=x_qLnBH ... CDgQ6AEwAQ It seems the Kawasaki factory splitter is a 2 screw affair that attaches to the coil mounts.I tend to think this would not be ideal.Comments?
My other bikes:
My other bikes:
- rbates9
Case splitting.
The design of that case in the picture is different from the newer liquid cooled engines. That book is for 83-88 air cooled engines.
GKBO
Case splitting.
Yes it is because that is the engine I'm dealing with.I could probaly just use the harmonic puller I have here to split the case on my 86 I think spreading the load is a better idea.Or am I just being paranoid and using the 2 coil mounts will be just fine?
Edit:Since this is a question better asked in the air cooled section I've asked it there http://kdxrider.net/forums/viewtopic.php?f=119&t=13390 to stop my inadvertent thread jack.
My other bikes:
My other bikes:
- rbates9
Case splitting.
It looks like for the case in the picture a two bolt puller should work just fine. The bolt holes look to be bigger then the stator plate mounting holes on the newer bikes.
And as long as you specify that it is an air cooled engine and it has to do with splitting cases then I wouldn't say your hijacking the thread. Just adding a note to the differences.
GKBO
Case splitting.
Decided I'd take the opportunity to try splitting the cases on my air cooled with the 2 coil mount bolts with this set up.
It worked just great,hit the bearing with penetrating oil and heat as well.Might just need new mains
My other bikes:
My other bikes:
argclh6670
Case splitting.
Nice write up. i didnt use a crank installer tool such as yours, i did the heat n freeze deal.
some like to use a torch...thats too risky i feel...heat gun is safer and quicker. As far as freezing, i used dry-ice, 15 mins was good. I gotta get that tusk too. nice tool.
To the OP, where did get that puller at? that thing is girthy!
- rbates9
Case splitting.
The crank puller is a Tusk from RMATV. The puller I used for splitting the cases is a Snap On wheel hub puller. The wheel hub puller will run you probably close to what you could buy another KDX for.
But it is what I had and it worked well. It is by far overkill and way more then you should ever need to split the cases. You probably wouldn't even need to take the case bolts out.
frenche200
Re: Case splitting.
Great topic! Excuse me if the question already been asked, but my feeble understanding of English make me some trouble to reading ..
I see you put the bearing in the half case first, and not on the crank: a particular reason?
thank you
thank you
i'm French and I don't speak English very well, so, please, excuse me :)
- scheckaet
Case splitting.
easiest way that i know.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Tedh98
Re: Case splitting.
Quick question/clarification on the crank installer. Does the base of the installer rest against the case or does it somehow rest against the inner bearing race?rbates9 wrote:![]()
I would think it has to rest against the case, otherwise the seal would be in the way and get damaged if the installer rested against the inner race. But if it rests against the case, it would cause a side load on the bearing when you crank is pulled through.
- rbates9
Case splitting.
yes. It sits against the case. It does side load the bearing but the bearing should be hard enough to not be harmed by it. Pretty much any way you put the bearing in will side load the bearing.
- Tedh98
DJNiedz
Case splitting.
i had the spare time, lathe, and mill. I made my crank installer rather than spending the money. worked like a charm (on my friends yz125, havent used it on my kdx yet, probably this winter).
scriberman
Case splitting.
Big engineering NO NO to side load ball bearings . I remove the crankcase lip so I can install the bearing correctly. Also means crank seals can be replaced without splitting cases. Plus plus.rbates9 wrote:yes. It sits against the case. It does side load the bearing but the bearing should be hard enough to not be harmed by it. Pretty much any way you put the bearing in will side load the bearing.
- Tedh98
Case splitting.
Do you have pictures of the retainers you setup to replace the lips you removed?scriberman wrote:Big engineering NO NO to side load ball bearings . I remove the crankcase lip so I can install the bearing correctly. Also means crank seals can be replaced without splitting cases. Plus plus.
I was going to attempt this on an extra set of cases but couldnt see bow to securely fasten a retainer.
I have found heating up the inner race is the way to go.
scriberman
Re: Case splitting.
No retainer needed. Seals are a nice fit in the cases , smear of wellseal is all thats needed. Most modern stuff just press fits from the outside. Done 3 engines so far, all running well.
riknull
Re: Case splitting.
A million thanks to rbates9 for the post and photos, they were a tremendous help while replacing crank seals on my motor.
However, I made a boneheaded mistake which I hope to help others avoid--I left 2nd gear off the input shaft and pressed the case crankcase together. When checking the trans through all the gears afterward, 2nd acted like neutral (no kidding!) and several gears seemed to be the same ratio. Without that gear in place, the input shaft could slide left and right within the cases.
All told it cost me a couple of days and $30-ish for a new left side crank bearing. The bearing stayed with the crankshaft when I took it apart, and I didn't feel comfortable putting it back in after being pressed off the crank. Pay attention, focus on your work, and don't do what I did!
