a little update.
The brute has been a pain really. Just because previous owner was a tool. NEVER ADJUSTED VALVES and at 230 miles was due for atleast two adjustments. Chains are stretched and cams are gone. Valves surprisingly weren't bad? Not sure if I caught it in time before or not. Chains are about 100 bucks and tensioners are about 30 a piece. So its not a total hit. Then I got a bright idea to get a hp kit for it instead of replacing with stock. In fact it is a bit cheaper in price.
Currently I have done
Rebuilt carbs complete and learned to sync them.
Rebuilt front differential.
2 inch lift up and 2 out
Rebuilt rear axle (pain in the ass swingarm bearings after fighting them I would of killed for some rusted kdx ones. )
2 inch snorkel kit ( homemade but its lookin bad ass. Couldn't finish too dam cold and glue was gelling on me)
dynatek cdi (eliminates almost all safety features like limp mode and also removes the timing restricitons and ups revs)
k n n air filter
gas tank mod (holes in skid plate for water and mud)
put an inline fuel pump (35 bucks 500 for the kawi one)
Whats coming hopefully soon
665 kit so I can use pump gas still
clutch redone
Im taking it to get rebuilt. Im confident I could do the rebuild however I have decided to take it to VForce John. The guy is truly out of this world in building a brute. Plus he tunes everything and also puts it on a Dyno to get the most out of it. He also specializes in the cvt clutches. Once he gets his hands on it I am also trying to get more saved for a muzzy dual exhaust. Hell also be able to jet it perfect with exhaust and snorkels with me in the driveway Ill just be guessing and going off of by ear so to say.
Considering its condition I don't ride it at all lately just been getting it ready to take and rebuild. The snorkels have to be finished and some other things to test the motor when done. But my plans are for it to be my trail buddy in summer for my kdx and winter its gonna plow. Couldn't use it this winter which sucked. But all in all I guess its a good thing considering I need different clutch springs in for the tire size and such. Belt wants to slip with the extra weight off of start.
Here is with 2 in lift installed and about to take front clip off to do a snorkel and radiator relocate kit on it. (just gonna weld one up I cant see paying someone 150 bucks for two brackets and some hose)
took a quick pick of snorkels. Not really going boating with it ....its just the dam choke cables Ive had nothing but problems with them. Theres two that connect to one and two plungers that move in or out for choke. The dam things always stick and cause problems I took the carb apart many times trying to correct. Now to choke I just muffle the snorkel a bit till she gets going. Why Kawi designed it like this is beyond me.
All in all its going well but I bought a rear storage box and going to make some speaker tubes and such. Ill be able to take it to the trail with tools to help dial in or repair and have some tunes. I also picked up a bike rack and will see about fabbing something to haul the bike. Didn't plan on doing it this way but I think it will be easier considering I park mostly on gas well roads and have to travel some distance to trails and sometimes across yards. Going back and forth to truck for tools is kinda out of the question. This way I can just pull the bike with quad to the trail and have a mobile tool box/cooler/tunes. It sits pretty high and figured I can even make some new trails with it.
