KX250 Forks on 94 KDX 200?
sailorcolin
What all would I need to put KX250 forks on my 94? It would just be the forks themselves, no triple trees or anything like that. Could I just slide the old shocks off and slide in the new ones, if they were the same diameter? The forks would be from an 05 or 06
- Has thanked: 5 times
- Been thanked: 15 times
Re: KX250 Forks on 94 KDX 200?
They will not be the same diameter. You will need the KX triples, and press the stem out of the KDX lower and swap it into the KX lower. You will most likely need the front wheel as well. This information is covered pretty well in this section, if you'll take a look around. :)
J.
J.
sailorcolin
