UFO Front Fender Part Numbers??
- Has thanked: 190 times
Does anyone know what the UFO part numbers are for the green, wide, front fender and the green, narrow, front fender??
Thank you.
Thank you.
karbon_dunn
The only bikes listed on http://www.ufoplastic-usa.com are for the KX125/250, they don't specify the years if that matters or not. The part number listed are Front Fender: 12-111 (doesn't specify narrow/wide/etc.).
Color codes:
Green: 22
Neon Green: 36
White: 29
Black: 23
Color codes:
Green: 22
Neon Green: 36
White: 29
Black: 23
Thanks for the help. Their USA site isn't too helpful, and I can not figure out (even through an Italian - English online dictionary) what all the Italian words are on their site on the PDF files showing various years. Maybe between this site and the Italian site, I can put it together.
Thanks, karbon_dunn!
- KDXer
Thanks, KAY DEE EXER. I will take a look at your pictures. Could you check the underside for a part number? PLEEEEEEASE?
Slacker.
- KDXer
Darn batcave.
Thanks, everyone. I got the correct part number for the parafango anteriore. OOPS! I meant front fender.
SUPER terriffic, KAY DEE EXER!
I had to look at that two times to catch it.
- quailchaser
So....What are the two different UFO part numbers?Jason wrote:Thanks, everyone. I got the correct part number for the parafango anteriore. OOPS! I meant front fender.
Narrow=?
Fat=?
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
KA02755021 is the lime green, narrow, front fender.
KA02700021 is the lime green, wider, front fender.
To me, "narrow" means 1995 and newer KDX style. My C and E models came with a wider fender than the 1995 and newer models.
