I've placed an order for a Maier rear fender for my 06 KDX 200 but I'd also like to find a suitable front fender that requires no modification (a direct bolt-on).
Preferably an Acerbis Fender that has a arrow/spade shape. Similar to this (that's a 2005 KX fender of some sort):
Thanks bates (can I call you bates?!). I ordered an Acerbis mx style for 2003-2007 kx125/250, hoping it's a direct bolt-on. I don't mind modifying but I want it to look as clean as possible.
That should work. If anything you may have to open the mounting holes up a bit or drill new ones. Either way it will never be seen once it is on the bike.
rbates9 wrote:That should work. If anything you may have to open the mounting holes up a bit or drill new ones. Either way it will never be seen once it is on the bike.
Jason wrote:Can you measure your front fender distances between the holes? I have the fender off my KX125 and am curious to see if they are the same. Thanks.
When I bought my KX front end it came with a fender (99) and the only difference between that fender and the KDX one is the guide for the odometer drive
-1996 KDX 200 plated street toy (barneyedition) -2003 Yamaha TTR125-L (wifeys bike) -1997 KDX 220 project bike
