Both sub valves not in same position and look cocked over a little, hmmmmm.
Cover and claw off (supported the shaft!) centre valve working but subs are not
Head and barrel off, remove every kips part to inspect. Only the subs are broken, in half and the pips on the bottom also. Does this happen on H as it seems to alot on E models?
Now i know the engine was fully rebuilt, no expense spared by a respected builder maybe 20 ish hours ago. Still fairly clean but does have some piston blow by because i know the PO did the as per manual run in.
Any ideas what would cause this and anything to look out for? Should i check the actuator and pin?
No ride for me this week but i guess it could be worse!
