Taylorville KYB testing....
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Over my 5 day ride at Taylorville IL. I had alot of opportunity to test my KYB's. They are pretty close to what I want other than they are still a little harsh on compression with them being at the limits.
.42 springs are correct for my weight and I think if I just remove a couple of the largest spring washers in each fork they will be just about right.
I still don't know if disabling the mid-valve would help but I may disable them anyway. I may just try this first before the end of the season.
The ground gets harder the colder it gets, so this may be a good test for the revalve.
Has thanked: 48 times
Been thanked: 15 times
...they are still a little harsh on compression with them being at the limits.
Do you mean you have the compression clicker adjuster turned to full open (soft)?
Thanks.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yup...actually one less than full. I always have a problem running anything to the limits.... :?
From holding one up to the light, I doubt most anyone could tell the difference between full out and one click short.
What is your weight in full gear?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Kinda personal ain't it? :shock: :lol:
Proly 200# give or take a pound or two....
Sorry if that sounded personal, but you know I am always researching this stuff. :grin:
