I found a 2001 KDX 220R, which although dated, has as great reputation for reliability and rideability. People rave about the power delivery and wide ratio tranny for woods riding. The biggest draw back is the less than stellar suspension, mainly the conventional forks. KX125/250/500 USD fork are a pretty common and easy swap. I started researching the project and pricing parts. Everybody seemed to want $500 for forks, triples, axle, rim and brakes. After that I would still have to have them revalved and resprung...another few hundred dollars.
While searching for forks I kept seeing late 90's early 2000s KX bikes with blown motors for the same price as most people were asking for the fork swap parts. I ended up buying a (what I thought was) '98 KX250 basket case for $325.
The plan was to stick the KDX220R motor in the KX frame. I know most people would wonder why anyone would bother messing around with such a project when 2005-2008 KTM 300s can be had for $4000-5000 all over the place. Surely I'll have to put thousands of dollars into it to even get it equal to a 5yr old KTM... so why bother? Well, because I have this mental illness that causes me to f%^k with everything. I can't just leave well enough alone. In that past that's been Chevy V8 swaps into Toyota pick-ups, 4Runners and Landcruisers. A 12valve Cummins swap into my Ford F450 and most recently a 3.4L quad cam Tacoma motor into my 94 4Runner. Messing with things is just in my blood.
The pile of parts above was Sunday March 17th. Things came together pretty quick.
The KDX getting stripped:
Piecing together the KX250 bits was a bit of a hassle. Buying a basket case is rough sometimes. You don't know the order of assembly, which spacers, washers, nut and bolts go where. Fumbled my way through.
Realizing that Dave had given me the wring triples for the bike:
Bye bye KDX:
Not sure why I weighed it but 51 lbs:
The biggest hurdle is modifying the KDX engine case and KX swingarm to work together. The through hole on the KDX case is 15mm and the KX swing arm pivot bolt is 17mm.
Some people take the engine to a machine shop to get it drilled on a mill to ensure it's 100 straight. I opted to buy a 17mm bit...$80...are you kidding :eek: I took my time, set up a jig and drilled it myself with no issues.
The next challenge is the width of the KDX engine boss is wider than the inner span of the KX swingarm.
Some trimming was required. Both sides of the 99-02 swingarms are like the right side of the 94-98 swingarm shown here:
On the 99-02 KX, you can simply trim the pivot area back and call it a day. The '98 swingarm requires some more thought and TIG work. I figured I need to cut 11mm off each side. These cuts aren't critical, they don't need to be perfectly square so the grinder and zip disc are all you need:
Had I known how thick the material was before I marked my cuts, I could have planned it out better and saved myself some TIG welding later. I know for next time.
FIller piece that will get welded in to cover the hole:
