floppy foot peg
terminatr
floppy foot peg
Post by terminatr »
Looks like the pin, the hole on the frame or peg are worn. The peg is floppy.
Looks like I need an over-sized pin. Any idea?
2001 KDX220
Re: floppy foot peg
KX pins are longer, but the same diameter. Another option would be to have the hole welded and re-drilled (the "whole lot of work and a pain in the butt"option). Is it the pin or the hole? If the other side is tight you can try it's pin and peg to see if its the frame mount hole or the foot peg hole/pin. You might also try Lowe's or Home Depot or Ace Hardware and look through the hardware pins.
rbates9
floppy foot peg
Post by rbates9 »
You could even make some out of some cut off bolts if you need to. Get a bolt that fits everything snugly with a long enough smooth shank and cut it down to the right size. Might be cheaper then pins but will require more labor.
Has thanked: 5 times
floppy foot peg
Floppy sounds like a spring issue. Even with a worn peg and pin it shouldn't flop with a good spring.
terminatr
floppy foot peg
Post by terminatr »
Oh yeah good idea.
The right side is nice and tight. But the left side is loose and floppy.
2001 KDX220
terminatr
floppy foot peg
Post by terminatr »
Worth $30 to keep the peg pin clean?
2001 KDX220
Re: floppy foot peg
Up here in the PNW it's just another place for mud and water to collect and sit unnoticed. My pegs get washed like the rest of the bike and then I hit the springs/pins with some WD40 right after to evacuate the water, never had trouble with them (other than trouble staying on them sometimes :grin: )
diymirage
floppy foot peg
Post by diymirage »
rbates9 wrote:You could even make some out of some cut off bolts if you need to. Get a bolt that fits everything snugly with a long enough smooth shank and cut it down to the right size. Might be cheaper then pins but will require more labor.
sounds to me like shoulder bolts would be the way to go
-1997 KDX 220 project bike
