http://www.eastwood.com/eastwood-torque-wrenches
Now Im used to the click type wrench but alas mine is no longer anywhere accurate under 40 lbs. This wrench and like most other digital ones you have an angle/degree to set as well.
What angle or sorry degree should I set that wrench to.
So far Ive set all the proper torque settings for front forks and such and put them at 030 degrees. Too tight? Loose.
The wrench is stellar tho. Audible buzzer with light. Almost like a stud finder feel. Feels very sturdy except for battery cover on end. Takes 4 triple a batteries has auto shut off and 7-100 ft/lbs range. =/- 2% accuracy.
I watched their videos but nothing on the matter of not having an angle setting or degree.
Side note good batteries in it and it has a back light. Batteries do come with it and the case allows you to store 4 extra. Case is sturdy too. Batteries are junk that come with it tho.
They had them on sale there for a while for 90 dollars
anyone else have a digital? Links to a better tutorial?
