yama-bond
kdx633
yama-bond
Post by kdx633 »
Which formula of yama bond is for sealing the center cases?
Has thanked: 5 times
Been thanked: 12 times
Re: yama-bond
I've always used hondabond. Didn't know there were various formulas of yamabond. Maybe someone knows, but you should be able to find something in the product description that says it's for sealing case halves.
yama-bond
You want Yamabond 4.
argclh6670
Re: yama-bond
Post by argclh6670 »
I use three bond 1194
kdx633
Re: yama-bond
Post by kdx633 »
thank you
royadams
yama-bond
Post by royadams »
I like loc tight gel seal. I'm not much on waiting over night for others to dry.
CoronasAndChips
Re: yama-bond
Post by CoronasAndChips »
I used Yamabond 5 and ended up with an internal leak about 600 miles after the rebuild. I was going to try Permatex Ultra Grey or the Hondabond 4 this time but then I remembered a couple years ago I rebuilt my Ski-Doo 583 Twin and used Permatex Anerobic (flexible) gasket maker which required a primer before application. Is there any reason I couldn't use that on My KDX as well?
My manual just says use kawi part# blah blah but doesn't specify wether or not it is a non hardening sealer.
Elbow grease contains no trans fat!
CoronasAndChips on XBox Live
BFBC2, BF3, COD 2,3,4, Black Ops, Red Dead Redemption, Tiger Woods 08' and 09' and Forza 2..... mostly
Re: yama-bond
If I remember right, Yamabond 4 is a flexible, non-hardening silicone, whereas Yamabond 5 is more like contact adhesive, which is probably what lead to a leak developing. You want the non-hardening type.
CoronasAndChips
Re: yama-bond
Roger that!
royadams
Re: yama-bond
Post by royadams »
The lock rite gel seal is an anaerobic sealer and works good and dries instantly. Gm make a anaerobic gasket maker as well,it can be bought at any gm dealer.
rbates9
yama-bond
Post by rbates9 »
loctite is who makes a lot of the anaerobic sealers for different brands. 515 is the part number for the regular flex. The primer is good to use but it is more to speed the curing time. I know of several applications that recommend not using the primer because the part can't be assembled quick enough and it will start to set too soon.
CoronasAndChips
Re: yama-bond
Just for kicks I called the local Kawasaki dealer to ask if they had the Kawabond #5 in stock. They said they used a pematex "Form a Gasket HT" and they don't use factory suggested sealers.
doh! :doh:
CoronasAndChips
Re: yama-bond
royadams wrote:The lock rite gel seal is an anaerobic sealer and works good and dries instantly. Gm make a anaerobic gasket maker as well,it can be bought at any gm dealer.
rbates9 wrote:loctite is who makes a lot of the anaerobic sealers for different brands. 515 is the part number for the regular flex. The primer is good to use but it is more to speed the curing time. I know of several applications that recommend not using the primer because the part can't be assembled quick enough and it will start to set too soon.
I'm going to use the Loctite Anerobic sealer.... It worked on my snowmobile.
