KDX220 kick starter loose
potosi joe
Post by potosi joe »
My kick stater is loose, and swings out to far letting your foot slip off when wet. Low on funds and don't want to built a full hybrid set up. Will the kick stater from a 2000 KX250 bolt in and work using the whole assembly? Thanks Joe
Has thanked: 5 times
Been thanked: 12 times
Re: KDX220 kick starter loose
I think so, Joe. I'm using a 99 kx250 boss with a kx125 lever. The whole 250 unit should fit.
doctord23
Post by doctord23 »
Yes. A kx250 kickstart lever from 02 and prior works great.
That's what I run.
You do still need to use a washer behind it so that the nut tightens.
I believe it is a 5/8".
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
cornishwrecker220
Post by cornishwrecker220 »
kx boss fitted to the kx 125 `shorty` kicker is one of the best/useful mods i`ve done to my 220.
potosi joe
Thanks guys. It looks like I will start with the 250 starter and go from there. Thanks Joe
rsr02
Post by rsr02 »
How does the full KX250 system fit? Any problems with the lever hitting the tank? Is it shorter then the kdx one?
1997 220, KLX forks-pipe-reeds-trials tire
