cold weather hand protection question
The wife and I are going riding next weekend. She is quite the trooper normally but suffers from freezing fingers this time of year. Anyone have any good ways to keep her hands warm? Here kx100 doesnt have a lighting coil so heated grips are out.
- diymirage
Re: cold weather hand protection question
have her wear latex surgeons gloves underneath the regular gloves
it seals in the heat and moisture
really works wonders for cold weather rides
-1997 KDX 220 project bike
- Has thanked: 5 times
- Been thanked: 10 times
Full cover hand guards like the ones from Maier block a lot of wind. Then, already mentioned, wear some type of surgical type glove underneath her normal gloves. There are also some "socks" that go on your bars so your hands can slip inside to help as well. http://www.rockymountainatvmc.com/p/43/ ... hand+cover
- diymirage
SS109 wrote: There are also some "socks" that go on your bars so your hands can slip inside to help as well. [/url]
i believe the correct term is "muff"
Never heard of the surgical glove idea. Really wanted the tusk muffs but Rm is out of stock
- Been thanked: 12 times
If you don't have full plastic guards on there, get them. They really do make the most difference. Aside from that, wearing latex gloves underneath riding gloves does help, but can promote blisters as well.
- rbates9
Try looking for "water proof" winter gloves. The thinner the better for dexterity. The gloves that are "water proof" have a plastic liner so they will keep the wind out and the heat in. And the muffs
or the mittens would help too. I can see the idea behind the latex gloves but if you are taking your gloves off very often then they probably won't be a great option.
She has the tusk bark busters with guards but they aren't big enough. I've seen some winter riding gloves but reviews are hit and miss.
- diymirage
rbates9 wrote: I can see the idea behind the latex gloves but if you are taking your gloves off very often then they probably won't be a great option.
i gues every one rides different from each other but when i ride i put my gloves on right before i put my helmet on for the first time and they stay on untill i pull back up to the trailer
- rbates9
For me cold weather that requires extra warm gloves means I'm out of the woods and on the lake ice. On the lake ice it is more of a social event. Ride for a bit, have a few beers, ride for a bit, few more beers and so on. In that case you are taking your gloves on and off a lot so something that is easy to use is nice. And on the open lake ice at near full speed for a duration with the cold temps and wind chill requires warm gloves. So I have found that the water proof winter gloves work well for blocking the wind and keeping warm.diymirage wrote:rbates9 wrote: I can see the idea behind the latex gloves but if you are taking your gloves off very often then they probably won't be a great option.
i guess every one rides different from each other but when i ride i put my gloves on right before i put my helmet on for the first time and they stay on until i pull back up to the trailer
The Maier hand guards fit the Tusk bark busters. That is the combo I have and you can see them on my bike in my sig below. There is a link there if you want to see bigger pics.jeeptech1 wrote:She has the tusk bark busters with guards but they aren't big enough. I've seen some winter riding gloves but reviews are hit and miss.
think im gonna go with these
http://www.atomic-moto.com/Moose-Racing ... p_197.html#
she will need more coverage than the maers ( i would like to hear nothing more than a mad chain saw kx behind me instead of a cold mad wife so erring on the side of cuation!)
Ame makes heated grips and a battery pack option. Its pretty high $140 for the grips $89 for the Batt pack $27 for charger. May be worth it if she rides a lot in the cold.
Figured I'd bring some thread closure. These moose racing guards work! Her hands only got slightly cold instead of hypothermic cold. For 25$ well worth it
Good deal.
