Which Conrod Kit?
Falcon911
Which Conrod Kit?
Post by Falcon911 »
Hi All,
Looking for recommendations please for a Conrod kit, main bearings, seals etc because mine need replacing.
Original equipment or a particular alternative and where is the best place to buy them in the UK?
Many thanks
Andy
suzuki 166
Re: Which Conrod Kit?
Post by suzuki 166 »
pj motorcycle enginers in wolverhampton do prox conrod kits main bearings and a seal kit they will also fit the con rod and balance the crank if you need it done look at there web site.
Which Conrod Kit?
I used a Hot Rods rod kit. It has a good reputation and can be found easily. As for any bearings inside the cases, I like factory OEM bearings only. I just don't trust aftermarket bearings of unknown origin. If you want an excellent crank rebuilder I highly recommend Cooksey Crank http://www.cookseycrank.com/#!
Falcon911
Post by Falcon911 »
Cheers for the reply Guys. America may be a bit expensive to send my crank too though lol
Been looking on the net and wondering what the real difference is between Hotrods, Pro-x and Mitaka - Mitaka are about half the price of the others??! Has anyone any recommendations on these makes (or disasters!) to share?
Thanks
Andy
suzuki 166
prox are a better make than mataka i put pro con rods in all my bikes with no problems i have 2 put mataka pistons in my kdx but it did have prox stamped inside the pistons i dont think mataka make a piston they just put prox in there boxes .
Falcon911 wrote:Cheers for the reply Guys. America may be a bit expensive to send my crank too though lol
You know, if you new guys put your locations in your profile we might be able to offer better suggestions! :busted:
rbates9
Post by rbates9 »
He does bring up a very valid point. :mrgreen:
I used a Hot Rods kit in my bike and have no complaints. I can't say it is the best, or the worst. It's a rod, it either works or it goes very very bad. So far it has worked.
Falcon911
Post by Falcon911 »
Once again thanks for the replies and reference location I did put 'UK' in the text on the initial post
Falcon911 wrote:...I did put 'UK' in the text on the initial post
See, I don't even remember seeing that. This old age thing sucks! :mrgreen:
Falcon911
Which Conrod Kit?
Post by Falcon911 »
Don't worry, I know exactly what you mean I do it all the time!
Cheers
Andy
