Tell me where to go?
canyncarvr
Post by canyncarvr »
Folkses:
Somebody had some good pics of a bent pin on an abused governator rod. I thought it was scheckaet..but, no.
Anyone with a pointer as to where, I'd appreciate it.
Thanks!
Has thanked: 5 times
The only pics I can find is from this thread: http://kdxrider.net/forums/viewtopic.ph ... 2&p=117808
canyncarvr
Re: Tell me where to go?
That IS a mangled pin, for sure.
..not the one I'm thinking of, though. The pics I have in mind showed a slightly off-parallel pin, one that with a quick look you wouldn't consider to be a problem.
Thanks for that one, though!
diymirage
Post by diymirage »
The one in the pic is mine and now replaced
The one your thinking off was in a recent post called '220 kips not engaging' IF I remember correctly
Im on the phone so I can not post the link
If your still looking in a few hours when I get home ill post it for you
-1997 KDX 220 project bike
diymirage
Post by diymirage »
Found it
It is called SLUGGISH 220
right here in the general section, just a few post below yours
canyncarvr
Thanks for that one, too.
Still...not the one I'm thinking of.
There is (was?) a pic of that pin and its parallel relationship to the governor shaft. The pin was bent..NOT parallel/'square' with/to the shaft. It wasn't easy to see, looking at it. But replacing it fixed the problem (didn't 'run right').
scheckaet
Post by scheckaet »
i have some pics on photobucket here is a link
http://s33.beta.photobucket.com/user/sc ... brary/kips
I can't recall which one are from the old bad actuator and which one are from the new actuator.
let me know if you can't see the pics
canyncarvr
scheckaet wrote:i have some pics on photobucket here is a link
So...I CAN see 'em, but you said to let you know if I could NOT see 'em..so I won't say anything about it.
That may well be what I've been thinking of...seems the tweak to the one I was considering was very slight. Which, is what I'm after..an example of a bent one that you need to look close at to see.
Hhhmmm...a couple of scheckaet's pics (with the tweaked pin) look to be bent in different directions. How'd that happen?
Again...thanks for the research, the looking and all. Much appreciated.
scheckaet
Post by scheckaet »
i took the pics a while back and meant to do a nice write up for the kips removal and what not but never got around to it.
still planning to do so later.
i think this one is the new pin
scheckaet
Post by scheckaet »
Every time i do a top end I order a brand new pin just to be safe.
I've done the mistake once to not support the shaft properly (really thought that I did) and it cost me way more than the 10-15 bux a pin with shipping cost.
The somewhat "bent" pin in the pics might be alright but I'm not taking the chance.
