How much trans oil?
How much trans oil?
Hey new to the forum probably an easy question for you guys. I have an 03 kdx the motor says .70 liters but put .40 in and its on the top line of the sight glass. I made sure it drained out well so do I ignore the sight glass and put the .70 liters in anyway?
- rbates9
How much trans oil?
It should take the .7. A lot of people even put in a quart. If you know the transmission was empty then it should take at least .7. When you drained the transmission was the bike leaning on the kick stand? or did you have the bike up on a center stand?
Re: How much trans oil?
I leaned the bike both ways I took it for a quick spin to get the oil nice and warm. So I should go by the sight glass then?
- rbates9
How much trans oil?
When you drain the oil you want to have the bike straight up, not leaning. That could be why it didn't take all the oil? But yeah if it is at the top of the site glass then you should be good.
Bike was straight up for ten mins as well and only took .4 liters and is to the top of the sight glass
Did you start the bike up, ride it around and check the level again ? It usually drops down a lot once the oil gets into all of the passages.
- rbates9
How much trans oil?
KDXsg wrote:should leaned the bike not straight up.
With the drain plug in just about the center of the engine you think that the bike should be leaned to the side to drain the oil?
lean it then straighten it back, do that a few times to make sure.
A true KDX customizer!!
BrokenChain wrote:Did you start the bike up, ride it around and check the level again ? It usually drops down a lot once the oil gets into all of the passages.
is a good point, a fair bit dissapears once youve run it up after initially filling
- dude541
agree 100% with the guys above,have this on my own.ukkdx200 wrote:BrokenChain wrote:Did you start the bike up, ride it around and check the level again ? It usually drops down a lot once the oil gets into all of the passages.
best regards
john
