1998 kdx 200 wiring diagram
200kdx200
Post by 200kdx200 »
If possible does anyone have a wiring diagram on this model? This bike wiring is a mess and for some reason I am not getting spark. I installed a brand new coil and I also did away with the kill switch thinking it might have shorted out. Any help would be greatly appreciated. Thanks :grin:
1998 KAWASAKI KDX 200
Re: 1998 kdx 200 wiring diagram
Try the Kawasaki.com site, select your bike and then Users Manual, it's a free download -->
http://www.kawasaki-techinfo.net/showOM ... ng_code=EN
If you're getting no spark, First thing to check would be output from the stator. Yellow lead from the magneto is the lighting coil, White/Red is ignition coil. You can check with a multimeter and should have voltage when you crank the engine. If so then likely culprit is the CDI unit (seeing as you already replaced the ignition coil. If not then you may have a shorted stator. Certainly don't want to ride without the kill switch. As a side note, a quick and dirty check for your lighting coil is turn on the headlight switch and kick the bike over while someone watches the headlight. If it lights the coil is ok. Doesn't help with your ignition problem tho :?
200kdx200
Post by 200kdx200 »
Great link, thank you! What reading should I be getting from the white/red wire when I kick start the
bike?
Should be in the neighborhood of 12V can't remember if its AC or DC, AC I think.
200kdx200
Post by 200kdx200 »
Thank you guys for all the help. I replaced the stator and I have spark!
KDXMainer
Country: Us
Post by KDXMainer »
Anyone used the replacement stator from RMstator? There's a dealer in Vermont that sells them.
2006 KDX200
1998 KDX220
Not a motorcycle one, but I used an RMStator on my 98 Sea-doo and it works great, was a fraction of OEM, and the build quality was pretty high on the unit I got.
