98 KDX 200 cylinder pic
- doctord23
It looks like it is sleeved and a pretty good job of it. The ports line up well.
This means:
1. You can hone it and see if you can clean it up. or
2. You can bore it to an oversize. This is cheaper than a re-plate.
Now people will give you their opinions on whether they like a sleeve or not.
Myself, I had an air cooled with a sleeve and had issues with reliability.
I would take a micrometer and find out what size the bore.
Stock 200cc is 66mm.
This means:
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
- doctord23
Re: 98 KDX 200 cylinder pic
Looking closer at the bottom view, it almost looks like a piece of the transfer port on the right side of the picture is missing behind the sleeve.
It might be the angle of the picture, but it doesn't look right.
That might be why they sleeved it.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
- scheckaet
looks sleeved.
FYI: another replate option is http://www.powersealusa.com/prices/
Strip, Plate, Hone $179
Weld/Machine $50
Weld/Machine $50
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Sleeved. I wouldn't sleeve a cylinder myself, given any other option. I also wouldn't scrap a cylinder just because it's sleeved. Especially not when the sleeve looks to be well installed, like yours does. I agree on the lower transfer, looks like a chunk was missing, hence the sleeve. Some of those gouges look deep enough to warrant an oversize, or two. Is there any marking on the piston? You'll need to know if it's already oversized.
There are some numbers on the piston but I cant read them all. The ones I can read say 0064E. There are some numbers also printed in the middle of the piston but those are the ones I can not read..
1998 KAWASAKI KDX 200
Thanks for all the help guys. This project has been a blast so far, hope to get it done soon. I will post pics when finished. While in progress I am sure I will have plently of questions.
Cleaned the piston and finally made out the number. It is 711M06600. Which is a Wiseco std size piston. Now I need to send off the cylinder to see how much they have to actually bore. Typically you would send a piston but with me not knowing how much it will need to be bored what should I do?
- doctord23
I would take it to your local motorcycle machine shop.
It likely would clean up at 0.50mm oversize but a shop could tell you.
Good luck.
Good luck.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
If you have to send it off for an overbore, I would just purchase the piston from whoever is doing the work. They will match it up for ya.200kdx200 wrote:Cleaned the piston and finally made out the number. It is 711M06600. Which is a Wiseco std size piston. Now I need to send off the cylinder to see how much they have to actually bore. Typically you would send a piston but with me not knowing how much it will need to be bored what should I do?
J.
Talked with my local shop. Its going to be 50.00 to bore and clean cylinder. Hopefully it will only need the. 50mm bore. Again thanks for all the help guys. Ill keep you post on the build.
- diymirage
i send my out to langecourt a few days ago
the cleaning was included in the price and the bore will be an extra 35 i believe
-1997 KDX 220 project bike
Getting cylinder back tomorrow, had to bore. 50mm to get rid of damage. About to start putting everything together this week. Anything that I should look out for? This is my first KDX rebuild any tips and tricks would be greatly appreciated!
- rbates9
50mm! WOW! That is going to make it about a 550cc.
