Exhaust o-ring
Exhaust o-ring
I need o-rings for my 1990 kdx-200 expansion chamber. From Kawasaki they're about 10 bucks apiece. I'm sure McMaster-Carr sells them for way cheaper, but I don't know what size they are. Could someone please inform me?
Thanks in advance.
Thanks in advance.
- diymirage
Exhaust o-ring
dont be afraid to put a bead of RTV sealant on it aswell
-1997 KDX 220 project bike
- rbates9
- Mr. Wibbens
Exhaust o-ring
If you don't have the o rings just use RTV, it seals up just fine
- Has thanked: 6 times
Re: Exhaust o-ring
Read up on the different types of o-rings made before buying any old o-ring.
Exhaust o-ring
Thanks much for the replies. I'll measure. I know that there is a high-temp material that exhaust o-rings are made from, Viton, I think it's called. If you've never bought from McMaster-Carr, you can get about 20 o-rings for 15 bucks. I'll check it out and report back.
- diymirage
Re: Exhaust o-ring
if you do get 20 ill take 4 of them off your hands...asuming you get the right ones ;)
Re: Exhaust o-ring
I pulled out the old ones from the pipe. I expected them to be halfway destroyed, but they were in perfect shape. I can reuse them no problem. I checked the McMaster Carr website and I was wrong about the price. They're about 5 bucks apiece. I was surprised because I bought a dozen of them for my KTM200 for a lot cheaper. Maybe the size is more common.
Exhaust o-ring
Sounds like you need to check how well the pipe fits into the cylinder it may be tweaked,and or the exhaust port may have some grooves where the Orings seal. I have 4 cylinders and they are all worn where the Orings sit, I always use sealer.kdxlnt wrote:I need o-rings for my 1990 kdx-200 expansion chamber.kdxlnt wrote:
Re: Exhaust o-ring
I re-installed the o-rings I took out of if along with some red RTV silicone. All is well, thanks.
- rbates9
Exhaust o-ring
FWIW, I have a FRP torque ring. With the torque ring it spaces the pipe out to the point that the second O ring can be seen from the out side. And I have never had any leakage from the pipe at the cylinder. Not sure why, but I haven't. I think it has more to do with the pipe fitting squarely into the cylinder with enough spring tension to hold it tight against the copper sealing washer.
