Hi there
I've got a 1991 KDX200 which is brilliant for its age. Only problem is I'm chewing through spark plugs faster than I can buy them. I get about 2 hours out of a plug before it needs to be cleaned or replaced. I'm running it at 40:1.
Any suggestions?
1991 KDX200 Plug Problem
What heat range plug are you using? The manual states a NGK B9ES but members on here told me to run a B8ES to help keep from fouling plugs. Also, is your jetting to rich?
Re: 1991 KDX200 Plug Problem
I'm running the NGK B9ES as per the manual. As for jetting, I don't think so but I can't be sure as I'm just learning. Any easy way to check/tell?
- Has thanked: 5 times
- Been thanked: 10 times
How to tell your jetting is off? Are you fouling plugs?CJ-D24 wrote:I'm running the NGK B9ES as per the manual. As for jetting, I don't think so but I can't be sure as I'm just learning. Any easy way to check/tell?
- rbates9
One more thing to keep an eye on would be the transmission oil level. If it is going down you might have a crank seal leaking.
