100 watt stators
kyle757
100 watt stators
Post by kyle757 »
Indawoods was making 100 watt lighting stators a while ago does anyone know if he is still offering these.If not who has quality stators for a 2002 200
scheckaet
100 watt stators
Post by scheckaet »
Sorry to tell you this but Inda passed away over a year ago...
RIP man.
scheckaet
100 watt stators
Post by scheckaet »
terminatr
100 watt stators
Post by terminatr »
I don't understand how rewinding it would increase the wattage. I understand the stock coil is
already wind as much as possible without it rubbing the flywheel. How would rewinding it making
much difference if there's no space?
2001 KDX220
diymirage
Re: 100 watt stators
Post by diymirage »
you rewind it with different gauge wire then what it comes with
thats about as technical as i get ;)
-1997 KDX 220 project bike
Has thanked: 5 times
100 watt stators
Yeah, we're not electrical engineers here. :mrgreen: All I know is that it is a proven way to upgrade your stator output. If you really want to know why I suggest Googling it or taking an electronics class!
diymirage
Post by diymirage »
kinda the idea of running water through 8 miles of river that is a half a mile wide or running water through 4 miles of river that is one mile wide...in the end, you still arent suposed to pee in a canoe
Roadhazardguy
Post by Roadhazardguy »
I think my dual coil stator should be at least 100 watts once I get it done, assuming all goes well...
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
100 watt stators
I tested my rewind to 103W. (see above linked thread.)
terminatr
100 watt stators
Post by terminatr »
If I'm using only a 35 watt bulb with a 100 watt stator, will the bulb blow because there's too much electricity?
Will light coil steal electricity from the ignition coil?
2001 KDX220
diymirage
100 watt stators
Post by diymirage »
terminatr wrote:If I'm using only a 35 watt bulb with a 100 watt stator, will the bulb blow because there's too much electricity?
first off, both coils produce electricity
so no, the light will not steal from the ignition coil, it will produce its own output, besides the ignition coil
(consider 2 cars driving in seperate lanes of the highway, if one if them speeds up that does not mean the other one slows down)
as for the bulb, 35 is the draw, or "need"
if you run a 35 watt bulb on a 75 watt stator that just means that you have 65 watts that go unused
so no, it will not blow
rbates9
100 watt stators
Post by rbates9 »
diymirage wrote: as for the bulb, 35 is the draw, or "need"
Or do you mean 40 watts that go unused? Check your math. :wink:
diymirage
Post by diymirage »
Actually ....what i ment was: when you run a 35 watt bulb on a 100 watt stator 65 watt goes unused
Not sure how i messed that one up
canyncarvr
Post by canyncarvr »
diymirage wrote:kinda the idea of running water through 8 miles of river that is a half a mile wide or running water through 4 miles of river that is one mile wide...in the end, you still arent suposed to pee in a canoe
Now THAT was funny! :grin:
1. Yes. You can improve the output of the OEM lighting coil by rewinding it. A thicker wire will get you a higher current/amperage, a thinner wire will get you a higher voltage. Increasing the number of core plates can also increase the power output. You are looking for more current. Attention TO the winding process (tight/even/close) also makes a difference. Some have simply RE-wound the existing wire to good effect. I wouldn't recommend that particularly..too much chance of a nick someplace ruining the whole project.
2. The one (current) or the other (voltage) is always a trade-off. There is no 'free lunch'. It's not difficult to end up with a coil that indeed can generate more power (watts)...but the bike has to be spinning over 2000rpm to GET there.
3. In regard to having an effect on the ignition coil, or 'stealing electricity' from it: For many years, Fredette used a rewound lighting coil as a spark enhancer. It was one of his secret weapons. He is right about that, it works that way. Why? FM, of course. There is apparently some change (compression) of the flux field with the use of a high(er) output lighting coil that indeed has a positive effect on the ignition coil (the ignitor..not the coil the spark plug connects to).
If you think there is no difference between an -ES and an -EG plug..if you have tried the two and can't tell the difference, I doubt you will notice the performance increase of the SPARK side when you change that light coil, though.
Oh...in the above noted link..TW was (is) correct. Do I have to read all six pages of that thread to get to the point the erroneous current reading is sorted out?
Is there a Cliff's Notes version? :wink:
Roadhazardguy
What if I have one lighting coil with thin wire and the other with thicker wire?
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
thuginfc
100 watt stators
Post by thuginfc »
What about the coils they sell on eBay? They seem legit just don't know if anyone has tried or tested them.
diymirage
Post by diymirage »
Roadhazardguy wrote:What if I have one lighting coil with thin wire and the other with thicker wire?
most of us only have room for one lighting coil on our stator plates, how are you gonna drop a second one in ?
Roadhazardguy
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
100 watt stators
Personally, I wouldn't chance that there would be a problem with running the two gauges of wire and just rewind them both with the same gauge wire. That's my .02!
canyncarvr
100 watt stators
SS109 wrote:Personally, I wouldn't chance that there would be a problem with running the two gauges of wire and just rewind them both with the same gauge wire. That's my .02!
As the eloquent VP of this once fine country might say: 'I have one word for you: Phase Shift!'
Well...kind'a.
More like two unrelated and separately generated voltages tied together WILL work...exceedingly poorly.
Electricity generation is not like beer: You cannot take a 12oz. can and a 24oz. can..pour both into a big glass...and get 36oz. of beer.
Yeah. I know. Amazing, but true! Electricity is NOT like beer. :lol:
Stay tuned for tomorrow's learnin: 'Electricity (transmission) IS like a doughnut!'
OBviously, I have too much time on my hands. I know that is true 'cuz I read it on the innernet!
