Proper warmup?
Racing220
Proper warmup?
Post by Racing220 »
Here in Colorado it's been getting a little chilly, and I was just wondering what the correct warmup procedure is
diymirage
Re: Proper warmup?
Post by diymirage »
not sure about the "correct" warm up procedure is but i generally kick it once, drive it out the drive way in a normal fashion and then wheelie it down the street and gun her to work ;)
-1997 KDX 220 project bike
dude541
Re: Proper warmup?
Post by dude541 »
diymirage wrote:not sure about the "correct" warm up procedure is but i generally kick it once, drive it out the drive way in a normal fashion and then wheelie it down the street and gun her to work ;)
:supz:
rbates9
Proper warmup?
Post by rbates9 »
If it is cold out then it wouldn't hurt to start it and let it idle while you are getting your gear on. Might need to blip the throttle a bit now and then, might not. I don't. Once mine is running and the choke is off it will idle till the gas runs out.
Thrahl
Re: Proper warmup?
Post by Thrahl »
I have heard that is isn't good to warm up 2 stroke by idling.
I start it with choke, let it idle for a few seconds, choke off, and then just take it easy until the engine is warm.
Then let'r rip.
Other people I know kick it, let it idle for maybe a few seconds then run it just as hard as normal. Just seems like a good way to cold seize to me. :rolleyes:
rbates9
Proper warmup?
Post by rbates9 »
Why do the people you have heard it from say that you shouldn't let a 2 stroke idle? If you have the jetting even close then there is nothing to be concerned with. A lot of people will tell you that you should not do this, or that but if they can't back up the argument then I wouldn't hold much faith in it. Do what you feel comfortable with.
cornishwrecker220
Proper warmup?
Post by cornishwrecker220 »
older bikes with steel liners take longer to warm up so it was advised to let them idle for a few minutes before riding else you risk a `cold seizure` when gunning them, modern bikes electro cylinders & better quality materials in pistons dont suffer from the above problem besides there are much better oils available nowadays which complement modern bikes...if you let a modern 2 smoke tick over for too long then you risk plug fouling & sticky powervalves etc..start it blip the throttle a few times turn choke off & ride gentle (ish) for a few minutes is the best way to warm your bike up... :grin:
tommyd
Proper warmup?
Post by tommyd »
I let mine idle for a minute then ride it gently for a minute or two, mostly because until it's warm it doesn't run that great at higher RPMs. Once it's warm it runs great!
Has thanked: 5 times
Proper warmup?
Cold seizures (aka; four corner seizures) still happen on modern bikes with the newer materials and cylinder platings. You can read about it all the time over at TT and other forums.
Anyways, I have stated this before, there is no way in hell I would just get on my bike and rip it. My engine is still fresh so I take every precaution to make sure I don't trash a cylinder and/or piston. My procedure is to start the bike. Let it idle on choke until it will idle on it's own. Leave idling while I put on my gear. Take off riding easy and feel if it revs cleanly. If so, start ripping!
kdx633
Proper warmup?
Post by kdx633 »
I start mine and let it idle with the occasional throttle blip until I can feel heat in the left side radiator.
Varmint
Proper warmup?
Post by Varmint »
kdx633 wrote:I start mine and let it idle with the occasional throttle blip until I can feel heat in the left side radiator.
+1
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
fuzzy
Re: Proper warmup?
Post by fuzzy »
This still holds true with tight piston clearance and forged pistons....AKA Wiseco installation....This is how they got their name 'Siezeco' it's not the factories fault.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
