Exhaust side: Vertical scratch marks
There's a little P on the top of the piston. Does that mean anything?
Single cylinder replate & diamond hone (aluminum or cast iron) $174.95
Single cylinder bore, plate & diamond hone (aluminum or cast iron) $209.95
Single cylinder weld bore damage (aluminum only), replate & diamond hone $229.95
Single cylinder repair detonation, replate & diamond hone (aluminum only) $249.95
Single cylinder rebuild damaged skirt, replate & diamond hone (aluminum only) $249.95
Do you mean my new Wisco piston or the old piston?KarlP wrote:Talk to the plater of your choice. They will probably want you to send your piston in with the cylinder.
I just went through this on my 200.terminatr wrote:Do you mean my new Wisco piston or the old piston?KarlP wrote:Talk to the plater of your choice. They will probably want you to send your piston in with the cylinder.
I believe "Single cylinder bore, plate & diamond hone (aluminum or cast iron) $209.95"terminatr wrote:Does the studs need to be removed before sending to Langcourt? If so, how do I remove them?
I just bought a standard size Wisco 220 piston. After I get the cylinder back from Langcourt, can I still use this Wisco piston?
What instruction do I need to give Langcourt?
Langcourts' price list:Single cylinder replate & diamond hone (aluminum or cast iron) $174.95
