It begins! '90 KDX200 rebuild
- Has thanked: 160 times
- Been thanked: 40 times
Great work! Thanks for sharing the rebuild.
- ss109
- Has thanked: 30 times
- Been thanked: 47 times
Now both wheels are completely done! Hopefully will actually start putting the engine back together this weekend... maybe. Seems like something always comes up and gets in the way right now.
KDX200-E2
Your bike is going to be TOO nice to ride! Better build a podium in your living room to display it.
Then get another bike to really ride.....
Love to see it when you are finished.
Jeff
Jeff
- ss109
I wish it would look that nice! I think it will be a solid 5 footer except for the fuel tank. I have tried everything to whiten it, and there were some very noticeable improvements, but there is still some discoloration in spots. Everything else should look pretty good though!
- diymirage
SS109 wrote:I wish it would look that nice! I think it will be a solid 5 footer except for the fuel tank. I have tried everything to whiten it, and there were some very noticeable improvements, but there is still some discoloration in spots. Everything else should look pretty good though!
have you tried polishing it with whitening toothpaste?
-1997 KDX 220 project bike
- ss109
No, Haven't tried that!diymirage wrote:SS109 wrote:I wish it would look that nice! I think it will be a solid 5 footer except for the fuel tank. I have tried everything to whiten it, and there were some very noticeable improvements, but there is still some discoloration in spots. Everything else should look pretty good though!
- ss109
Oh, yeah, I almost forgot. I picked up a few more items for my build. I bought new Motion Pro clutch (Terminator) and throttle cables and new No-Toil air filters.
Frysk
- ss109
Soda blasting! Works awesome on cast aluminum parts.Frysk wrote:How did you get your hub so clean
- rbates9
SS109 wrote:Soda blasting! Works awesome on cast aluminum parts.Frysk wrote:How did you get your hub so clean
Frysk
- ss109
Funny as neither do I!Frysk wrote:Hmm, to bad I don't know anybody with a sodablaster
- ss109
OK, I got the trans shafts reassembled and ready to go. Just dropped my crank into the right side case and waiting for it to cool off. Next, install the trans!
BTW, to any who haven't tried the heat case/freeze crank method for installing the crank, it works like butter! I left my crank in the freezer overnight, then heated the right case half from a cold oven to 225 degrees for about an hour, and the parts slid together with absolutely zero resistance. I plan on doing the same for the left side as well.
- rbates9
I thought about heating and freezing for the left side as well but I was concerned about using the case sealer on a frozen surface then dropping a HOT surface on it. I don't know how the temperature difference would workout as far as having a good bond and seal.
Let us know
Let us know
- ss109
I don't think it should be a problem. I guess I'll find out for sure before long! I'm kind of on hold until I get a new case bolt as one is bent. I won't get into how that happened but suffice it to say that it had to be the odd ball long one.
Oh, yeah, just got back from dropping my frame off to have it sand blasted. They are saying it is roughly a 10 day wait right now so time to work on other parts.
- rbates9
I know a guy that has a crank puller that works great for getting the cases back together.
- ss109
Well, it isn't me so who might it be? I would love to have a loaner!rbates9 wrote:I know a guy that has a crank puller that works great for getting the cases back together.
- ss109
I remembered today that I have a spare KDX trans so I started really looking at my gears and realized the 6th gear on the output shaft the dogs have very noticeable wear on them. So, I pulled the one from the spare trans and the dogs are in great shape! Unfortunately, there is some damage to two adjacent teeth so now I'm stuck trying to decide which one to use or if I should be looking for another one. What do you guys think?
Original gear is on the left and the spare on the right. You can see the dogs are worn pretty good. (click it for a bigger pic!)
OK, here is the damage on the spare gear's teeth circled in red.
david
- Country: UNITED STATES
The 'damage' on the spare is nothing. Dress it with a file and run it.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
