I also found some nice wear marks in the basket and chips an scrapes in the rest of the rotating mass.
Is this bad enough to replace or just file and reuse?
We will check when I get back with the magnet to determine iron on alum.scheckaet wrote:as for the metal in your oil, are you sure it's not clutch fiber?
Did you soak your clutch plate a few hours before installing them?
is it aluminum or iron based? use a magnet.
