Revloc?
- fulltiltboogie
Revloc?
Anybody have the Revloc clutch? I'm on the verge of buying one.
I read alittle on that link page you put up Indi. My question on these auto clutches is how do they react on hills when you need to feather the clutch and what about race launches? It sayd to put into first anf gradualy increase the throttle. What happens if you just pin it? The bike pin you?
Ok I read alittle further, sounds cool. What do these little gems run $$? I just may not be done modifying yet. :eek: I tired to go through thier on line store but could'nt find the application. I guess you have to contact them.
Jon.
Jon.
- skipro3
I have the EFM auto clutch and my riding buddy has it in his KX500. From idle, in gear, pin the throttle and you will loop the bike. Just like dumping the clutch on a standard bike. Except you won't stall it. Imagine having a miniature Jeff Fredette sitting on your handlebars working the clutch for you. That's what it's like. Just about the time you start grabbing for the clutch, it will start slipping for you. Heck, leave the bike in a gear taller than normal and it will slip just fine and save you from shifting as much. A little hard on the clutch plates and they will wear more that way, but I'm here to tell you, I won't own another dirtbike with out the EFM autoclutch.
The EFM auto clutch mod costs about $500. It isn't cheap. But then I think it is the most useful mod I have as well. Dollar for dollar the best investment I've made. Call Garry. He's easy to talk to. He started designing the EFM autoclutch around his own KDX. So that tells you something. He builds them for all sorts of bikes including Harley's and, like I said, a KX500 so the KDX isn't going to tear it up and break it.
Jerry
The revloc is a whole lot more money, right? (Yeah...I could go look it up...but I'm lazy! ..heard that somewhere...anyway)
Isn't there some other issue with Revloc that makes it less desireable than an EFM?
For quite awhile, there was no KDX clutch thru Revloc.
In answer to ftb though, from what I've read and heard the EFM not only costs less, but it's better for some reason or other.
Ski: I'm sure you looked into revloc before you opted out of the clutch crowd. Why did you choose EFM?
- skipro3
I'm pretty sure Revloc still doesn't make a unit for the KDX. The KDX clutch actuating arm is on the "wrong" side of the basket for a revloc to work. I've talked extensively with a Yamaha owner who has revloc. It's nice but took several rides to break in and get a final adjustment. Mine took one ride and one adjustment that was made on the trail in about 15 minutes.
The EFM uses your existing clutch, so there's no going back. Also, no clutch lever to override. Again, due to the way the KDX clutch engages. My KX clutch lever will still work with an EFM and simply override it when I want. But I will be getting a hand operated rear brake so that won't matter. That hand rear brake is the most precise and fast, much faster than a foot brake. With SS braided brake line and using 2 fingers, I can feel the rear tire knobs roll over the ground though the controls. Now that is precise.
The bike will be in Oregon for test rides. And for crying out loud, CC, you can ride it more than 10 minutes. I know you are afraid you will want one. BTW did Jeff sell you anything?
And where are the fancy smile faces Inda uses? I don't see them.
Jerry
