1994 KDX 200 enging running backwards
chainguard
Post by chainguard »
She stopped while riding like it fouled a plug. Spewed a little oil from the case breather tube. Now she runs in reverse. Kick start or bump start, same. Spins the tire backwards. Most wierd. I cant be only one in the history of KDX. It ran flawless for the last five years.
Thoughts where to begin? Tranny problem?
Chainguard
doctord23
Post by doctord23 »
Flywheel key or timing.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
gsa102
Post by gsa102 »
I agree, most likely the Flywheel key. A 2t engine can run backwards if you change the spark timing.
96 KDX 200, 09 YZ 250
Flywheel Key.
chainguard
Thanks. I will look and see. Do I need a special puller?
Chainguard
Has thanked: 5 times
Been thanked: 12 times
Yes, you'll need a flywheel puller. I got mine on ebay, but any parts store should have them. It's 27mm x 1.0 LH thread.
Going to move this to the E series section :).
J.
chainguard
what is the cut off for E and H series bikes?
Chainguard
rbates9
Post by rbates9 »
chainguard wrote:what is the cut off for E and H series bikes?
95-06 = H
89-94 = E
chainguard
final question, mine has the inverted forks, 94 or 95?
Chainguard
93 or 94.
chainguard
any reason the inverted forks were only short lived?
Chainguard
Not sure. Those particular forks were really not an improvement over the conventionals. Same internals, just flipped upside down. Perhaps a little less flex and obviously less underhang. They couldn't make the kdx TOO good, else they would have lost sales on the KX, lol. Someone had thrown a set of 94 USDs on my 89 before I got it. They worked well on the single track, but made me nervous as hell trying to ride fast on open trails.
Terrence Sprocket
Post by Terrence Sprocket »
As far as your KDX running backwards, buddy of mine had the same prob with his old IT 175. Turned out that the stator plate shifted off timing. Which is weird cause it didn't move that much. Wouldn't think thatit would make it run backwards. Just make sure the timing marks are In sequence. Good luck!
KDX ALL THE WAY!
dfeckel
Post by dfeckel »
So, how can the kicker start the engine in reverse? I would think it could only if it gave a major kick-back when it started.
David Eckel
Exactly. As soon as it "catches" the engine kicks back the other way.
