HELP!! I can't get my Kdx to tick over!!
I blew a hole in my piston so was forced to rebuild the top end. It never ticked over in the first place but I would like it to now. Any suggestions welcome, I'm not bad with a set of spanners and am willing to take the carb apart, just no idea which bits to bend or tweak.
The best I have had so far is an idle around 3-4k rpm but then it just dies if I don't keep the revs on.
1988 KDX 200 1991 swing arm conversion (rear disc)
- scheckaet
Would you write it in proper English plz?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
Seriously, I'm not sure what u meant by: "never ticked over in the first place but I would like it to now"
I assume you're talking about carb jetting, more info would be useful to help u out: what model/year bike u have, mods, altitude...
If you having carb issue, this is a good start:
http://www.kdxrider.net/forums/viewtopic.php?t=1156
Also, why did you blew a hole in the piston?
(I have the feeling you have a 220...)
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
It may have been a 220 but after the blow hole, I have had the barrel put back to the original size and I a now running the stock piston. The bike would not idle when i bought it. I assume the blow hole was because the fuel mix was to lean.
It is a 1988 model, not sure of altitude, i live in worksop, uk if you coulp help me with that?
I believe correct jetting could solve my problem.
Help is very welcome in any form.
Thanks.
Thanks.
- rbates9
I got round to doing it a bit earlier than I thought
Fletch, you are an absoloute star. The pilot jet had a bit of crap in it. I have stripped the carb apart and cleaned all the jets and returned the jet needle back to the 2nd position as it was on 3rd for some reason.
For 3months I have had this problem and finally, solved with 15minutes work and advice from some good people.
Tick over means engine idle (Sorry for the mis-understanding)
I am now able to warm the bike up at 1-2krpm and not 3-4
Cheers Fletch
Cheers Fletch
Your welcome.
your thanks to this site is well deserved, I have learned tons here too.
I'm wondering what can cause an engine to melt a hole in a piston???
You may want to check that engine for crank seal leaks or other leaks elsewear. Pull the l-side mag cover and look for oily resedue on the bottom of the flywheel.
Fletch
89 kdx 200 with 99 rm125 forks
- scheckaet
how far is your idle screw in?
Mine revs really high when cold then goes back down when at running temp...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
still haven't told us what's your jetting and mods you are running...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
pilot and main #?
How many turns on the air screw?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
I have the bike running at 1.5 turns on the air screw. Aparently any more than 2 turns can damage the engine?scheckaet wrote:pilot and main #?
I will keep you posted maybe mid-day saturday (GMT) with the jet sizes, a bit too busy at work today to be taking the carb off again and I will no doubt be out for a beer tonight being as it's friday
Speak to you all again very soon and big thanks well deserved up to yet
That's inaccurate. From what I recall of carbs you can run up to 2.5 turns or so out. Even with more than that it won't hurt anything, it's just recommended to swap to a different pilot jet for better tunability after 2-2.5 turns.Mart56966 wrote:I have the bike running at 1.5 turns on the air screw. Aparently any more than 2 turns can damage the engine?scheckaet wrote:pilot and main #?
