This time of year a lot of riders are doing rebuilds and upgrades. If your doing your stem bearings and have a mig welder you can use, i can save you hours with a die grinder.
-With your races in the frame run a light bead all the way around the middle of the bearing race, let cool and it will fall out. Repeat on the bottom race and done! Just a helpful trick I've learned.
-Matt
Stem Races
- kdxquebec
- Mr. Wibbens
Never had any trouble getting them out with a drift
- gsa102
This is great info. I have an H motor that I want to rebuild this winter, but I've been delaying the start because I wasn't sure how to remove the outer race of the lunched countershaft bearing. I considered cutting notches so I could get a drift onto it and hit it from the other side, but this gives me a semi legitimate reason to buy a welder :)
This also would have made replacing my last set of stem bearings in my Husky easier, too. I had a heck of a time getting the top race out--there was only the tiniest lip of the race to get on with a thin screwdriver (which is now ruined, but the way). Probably took me the better part of an hour of pounding to get that thing free.
David Eckel
- gsa102
