RB and Jeff Fredette
Questions and Answers about the best carb and Head mods available for the KDX.
MadMax
Post by MadMax »
Has anyone run the RB modded head and carb with a cylinder ported by FRP? I already have the RB mods done and thought about sending the jug off for some massaging.
MadMax
Jedi Master Team 5150
scheckaet
Post by scheckaet »
It's been tried before and as far as I can recall, they didn't match too well, bike didn't run well.
MadMax
Post by MadMax »
Thanks.
MadMax
turtle
Post by turtle »
You might want to do a search. I recall reading something on ths exact topic recently ...
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Has thanked: 10 times
Been thanked: 17 times
Yeah, as I recall it didn't work out so well. Freddettes porting is obviously designed with the stock configuration in mind, likewise for RB's mods. Putting the two together, neither party would be able to guarantee the results...
fuzzy
Post by fuzzy »
Whoever cuts your ports should cut your head. Don't see anything wrong with carb mods on anything with a PWK, in any porting configuration....Just don't expect the jetting to be perfect without fiddling on your part. That's all pretty well ironed out on a stock cyl KDX w RB carb.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Green Hornet
Post by Green Hornet »
Mine work well together. I noticed gains EVERYWHERE...I have RICHENED the Carb Circuits Slightly ( a tad larger on the Pilot) & adjust the Airscrew & Needle as Needed....I did Feel a Much Larger Power Increase from the Lower to Mid Range & Top End Response is MUCH BETTER....I asked Jeff to do a Moderate Port Job. I have not ridden the 220 much since i bought the KLX450, but my 18 yr. Old Son, is planning to ride it, so I need to re-install the handlebars, install the New Seat Cover and tighten and re-inspect miscellaneous parts....... :supz:
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Mr. Wibbens
Post by Mr. Wibbens »
Carvr had a Fredette port job and replate
If memory seves...
The porting was not so much the problem as was the fact that the bore was out of round and the plating job was complete crap. Cylinder was all pitted as was the mating surface for the head
canyncarvr
Post by canyncarvr »
Mr. Wibbens wrote:Carvr had a Fredette port job and replate
If memory seves...
His memory serves him well. It was out-of-round and the re-plate job was pathetic.
I tried getting that cylinder (ported for improved bottom, no racing, pump fuel...and leave the exhuast alone) to run for at least a couple of years. 1. It never did, and 2. An OEM cylinder worked (and works) MUCH better.
The exhaust port was modified, too. Just a bit of a 'notch' in the middle of the top. The result (apparently..I'm not a Port Doctor..and I don't play one on TV) was a continued battering of the sub-port drums, particularly the RH drum. Broke one in 1/2. The brand new replacement drum had the teeth chewed up.
US Chrome did the replate. The cheesecloth effect they left it with was advertised as a +: A place for oil to live.
BS. :butthead:
Two local engine builders saw the cylinder after it was 'ported'. Both expressed incredulity that such lousy work would EVER leave a shop! And THOSE comments were NOT made about the re-plate.
I don't know who did the port work on my cylinder. I sent it to FRP. Maybe it was 'Billy Bob's' tryout jug.
Mr. Wibbens
Well I'll be, hell musta froze over
Brian
Post by Brian »
Holy S**t!!! I thought Wibby was replying to an old post untill I noticed the date...
Mr. Wibbens
Musta been a pretty slow day at CCM
Varmint
Re: RB and Jeff Fredette
Post by Varmint »
Me too. Thought this was an old post. Glad to hear from you CC!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Fletch
Post by Fletch »
Hey Carvr! I was just getting on here when you were leaving. Thought I smelled bad... Nice to hear you're still around.
Fletch
89 kdx 200 with 99 rm125 forks
canyncarvr
Fletch wrote:Hey Carvr! I was just getting on here when you were leaving. Thought I smelled bad... Nice to hear you're still around.
Not that I'd know you don't......
Mr. Wibbens wrote:Musta been a pretty slow day at CCM
Every day is a s-l-o-w day where I be.
:hmm:
Maybe there's a connection between the two?
Nah! That couldn't be.
KarlP
Post by KarlP »
Welcome back CC
I've been trying to keep this place together while you were gone, it has been tough.
'08 KTM200xc
KX100 for the boy
