Got the conversion mostly done...
MadMax
Post by MadMax »
Still have to work out the odo cable routing and get a black seat cover..
Here's the before pic:
Here's an after pic:
and another:
Whaddya think?
MadMax
Jedi Master Team 5150
heckler
Post by heckler »
how did you mount the headlight? I"m in the same boat, and want to keep my light.
220ripper
Post by 220ripper »
looks sick ! where did you get the decals from? They custom?
MadMax
Post by MadMax »
Headlight mounted with the stock KDX mounting tabs.
Decals are a mixed bag. The shrouds and front fender graphics were custom order from PG. The numberplates and headlight I just bought blank black vinyl (FX I think) and trimmed to fit. Lot's of hair dryer use on the headlight to mold it to the shape. I'm no artist and the edges aren't perfect but it looks good from a distance.
MadMax
rbates9
Post by rbates9 »
Nice Bike!
heckler wrote:how did you mount the headlight? I"m in the same boat, and want to keep my light.
I used the top KDX mount and a set of UFO? replacement rubber straps for the bottom. It worked out very well.
As for the odo cable I ran it thru the stock clutch cable guide that came off the KDX triple clamp that I could no longer use, mounted it to the right fork guard guide bolt. So far it has worked out ok.
fuzzy
Post by fuzzy »
Nice!
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
KDXsg
Post by KDXsg »
it is not nice. the oem looks better.
A true KDX customizer!!
Mr. Wibbens
Post by Mr. Wibbens »
KDXsg wrote:it is not nice. the oem looks better.
you're an idiot
Varmint
Post by Varmint »
Mr. Wibbens wrote:>|<>QBB<
you're an idiot
:lol:
You've been wibbenated!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
KDXsg
Post by KDXsg »
:butthead:
Mr. Wibbens
heckler
Post by heckler »
so, what's the trick to installing the damned wheel on these monsters?
I had the frame supported, but not so the front wheel was in the air. Had to push up on the forks to get the front wheel on, and my first push down on the forks resulted in no movement at all of the forks - very disappointing.
I know about the "loosen everthing off and hit the brakes", but that didn't work either. I know the forks are binding, because they move independantly no problem.
I'm thinking of getting the frame supported high enough so the front wheel is off the ground with full extension on the forks. Will this help?
Never mind... Found the fork installation thread. Yup, lift the frame - front wheel off the ground.
bman
Re: Got the conversion mostly done...
Post by bman »
>|QBB<[/url]
MadMax wrote:Still have to work out the odo cable routing and get a black seat cover..
and another:
where did you get your mx front and rear fenders and would they fit my 85 kdx?
Whaddya think?
15 years old
85' kdx 200
heckler
Post by heckler »
madmax, it's time for a new (black) seat cover. Install is quite easy with a stapler and some patience.
swatts
Post by swatts »
Love the trials tire, love the new forks, love the headlight. Surprised to see an OEM kickstarter still alive, surprised to not see any pip guard at all, but good job.
Fatherof2
Post by Fatherof2 »
Can you give us a ride report?
MadMax
Post by MadMax »
Fatherof2 wrote:Can you give us a ride report?
Sorry, been out of commission. Had an ATV accident and almost killed my silly self. Bike runs and rides great. The new FMF Q made a difference over the old Turbine Core. Bike lost just a bit from the bottom but now it revs like a MX'er. Forks are both an improvement and a problem. Stock springs cause the front ride height to be low, I changed the fork oil from 5w to 7w and added 20cc's to each leg over stock but it still is a bit like a stink bug. I'm researching and saving for stiffer fork springs. According to Jeff Fredette's site, for stock KDX forks, a .38 would be great for my weight - but on KLX planet, their chart shows .42 for the KLX forks. Can anyone share some wisdom here?
Thanks!
MadMax
MadMax
Post by MadMax »
Oh, and to answer bman.... Got the rear fender from Fredette Racing. The front is just a new KXF 250 fender (Acerbis) that I ordered from Motorcycle superstore or Rocky Mountain or one of those places I do business with. I'm guessing the front would fit yours but I doubt the rear would.
MadMax
The KLX forks are soft with stock springs. They need to be swapped out.
Your forkguard guides are on the wrong sides.
gsa102
Post by gsa102 »
For the fork springs, I would err closer to the KDX setup, because the KLX frame and engine are most likely heavier than the KDX frame and engine. I would look those weights up and compare them. With those two numbers I might try a .40, but I am fat and go over small jumps on occasion.
96 KDX 200, 09 YZ 250
