Once done with that I guess it's on to stripping the paint and repainting it, not certain why it has the '88 green though the entire swing arm was painted the same green too.
Interesting. So were you using the stock trip meter sensor on your KDX? I will use the stock sensor I have, the meter and most of the cable like so many on these these old birds was cut off. I can figure out the wiring I'm sure it's not too hard, but just wondering if anyone already knew which wire is which since it's not clear in my Clymers manual.scheckaet wrote:thought about it, but the unit I got needed to be extremely close (1 mm) to the magnet.
. That's what I was wondering, thank you.skythrasher wrote:There is a circuit board in the wheel sensor not just a magnet and sensor.
That's a very good point Fletch, thank you. I had only considered boring over to be a problem since that would remove the electrofusion for certain, but after consulting my clymers and doing some reading around the web I will take your advice. Thank you!Fletch wrote:Careful on the honing. If that is an electrofusion bore then a scotchbright scrub with wd is all it should need. honing could damage the plating.
lookn good
