i have just picked up a 200 carb for my 220 ..the carb looks identical to the 1 on my 220 albeit the jets etc are that of a 200...i was wondering how i can check to see if the carb is actually that of a 200 as there are no i.d markings on the carb body stating weather it is pkw 33 or 35...where would i measure to check the size & what would a 200 measurement be ? thanks.
Teh carbs are identicle aside from the internal bore, and as you have already noted, the 200 carb would be 35mm ID as measured on the intake manifold side of the carb throat.
