KXF250 front brake discs........
GreatBritishRob
Post by GreatBritishRob »
actually do fit the KDX220R. Very handy to. Now got a nice wavy front disc brake on my KDX. No doubt everyone already knew that but theres not a lot of call for the KDX in Britain so its mostly trial and error. :supz:
Velocity_Stack
Post by Velocity_Stack »
Not everyone knows that, I surely didn't.
Thanks for sharing.
Gives me options when the time comes.
GreatBritishRob
Only thing you have to do is either drill out the mounting holes a little bit to use the original bolts as they have a collar on or simply use normal 8mm bolts. Thats ok as the disc only comes under load one way anyway. Apart from that the diameter, internal and exterior is the same, mounting holes etc all in the same place. Fitted mine last night and the wavy disc looks a treat and its solid which personally i prefer. :mrgreen:
Has thanked: 5 times
Been thanked: 12 times
Awesome, I had no idea!
cj555rally
Post by cj555rally »
Nice find Rob! Any ideas for the rear as i could do with both......
Any particular year kxf?
rbates9
Post by rbates9 »
I drilled out the bolt holes on a 2000 KX front rotor and it fit like it was meant to be there.
SCREAM
Post by SCREAM »
good info. what year kxf was it from?
GreatBritishRob
Sorry about the slow reply gents. Apparently its the 2004/5 model KXF250. If you do order one order the mounting bolts at the same time as it saves drilling the holes any larger. Peachy :mrgreen:
KarlP
Post by KarlP »
Good stuff.
Things like this should go up in a sticky
'08 KTM200xc
KX100 for the boy
SCREAM
Post by SCREAM »
KarlP wrote:Good stuff.
AGREED
GreatBritishRob
I'll get a picture or 2 put up tomorrow. Sorry, been a bit busy with trying to give up smoking and as a consequence, wanting to kill everything :mrgreen:
cj555rally
Its all in the mind my friend..........and the kxf of that year use 6mm bolts instead of 8mm like the kdx (so im told) so get drilling!. Keep the power :neutral:
Ask, and you shall recieve. :mrgreen:
rbates9
Post by rbates9 »
juliend wrote:>|<>QBB<
Ask, and you shall receive. :mrgreen:
Mabe name the sticky something like "What parts will fit a KDX?" or something like that. I know there is a few other parts that can be interchanged and or modified to fit a KDX. I found a lot of the KX trinkets to fit the KDX as well and I'm sure there is more.
This thread should be added to the "Best of the best mods" thread and left at that. We are starting to get way too many stickied threads already and is cluttering up the forum. Things need to be organized and condensed.
BTW, Slick Nick's thread on stator rewinding should be added to the "Best of the best mods" thread as well. It is by far the best thread on the topic ever on this forum.
Thanks for the advice, and the constructive criticism too. We do need to clean up the stickies, but it'll take some time. Putting it up here for now will keep me reminded to condense that stuff.
Sounds good. :partyman:
KDX Butterfly
Queen B
Queen B
Post by KDX Butterfly »
juliend wrote:Thanks for the advice, and the constructive criticism too. We do need to clean up the stickies, but it'll take some time. Putting it up here for now will keep me reminded to condense that stuff.
Any stickies "post-February 3, 2011" that were posted by me regarding the website and Vince's death, i.e. buying things from the website; anything that has already been cleaned up and updated regarding that time can be removed. If you question it, ask. I will start working on it when I can.
"If I were just two inches taller, I wouldn't be me." ~KDX Butterfly
GreatBritishRob
Im easy :lol:
