What is the difference?
Fatherof2
Post by Fatherof2 »
What is the differecne between this:
.................and this?
If both are a GL-5 then nothing.
scheckaet
Post by scheckaet »
dunno much about oil but isn't that really thick for tranny oil?
gregp
Post by gregp »
The HP will waste your money a bit faster than the Pennzoil. Your transmission will shift worse with either one (in comparison to regular old 10w-40). JMO, based on my own experimentation with each.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
Has thanked: 5 times
Been thanked: 12 times
My old F11 loves the honda HP oil for some reason. Ran it in my KDX for a whlie, but the KDX likes ATF much better. Don't be afraid to play around with many different gearbox oils. The biggest thing you will notice is different clutch/shifting feel. Pick what seems to work best in your bike and run it. Just stay away from oils with friction modifiers in them.
Fletch
Post by Fletch »
I ran gl-5 gear oil in my vw tranny and it was hell on the syncromesh. I switched to a gm syncro trans fluid also gl-5 and it was night and day.
So to answer, additives
Fletch
89 kdx 200 with 99 rm125 forks
gregp
Post by gregp »
My current H series KDX seems to like regular 10w-40 best. Even with that, it only shifts well for one or 2 rides, then it starts getting very notchy.
SOARSKI
Post by SOARSKI »
scheckaet wrote:dunno much about oil but isn't that really thick for tranny oil?
Here is a thread from 2009 that has some good info.
http://www.kdxrider.net/forums/viewtopic.php?t=7241
canyncarvr suggest:
You referred to it maybe being 'too thick'.
Gear oil specs are not the same as motor oil specs. Some think that a gear oil rated at 80W is somehow twice as thick as 40W motor oil.
It's not.
Quote:
API viscosity ratings for gear oils are not directly comparable with those for motor oil, and they are thinner than the figures suggest. For example, many modern gearboxes use a 75W90 gear oil, which is actually of equivalent viscosity to a 10W40 motor oil.
From HERE!
HERE is the article he is referring to:
http://en.wikipedia.org/wiki/Gear_oil
