Update: well, I managed to goof up the starting procedure I had in mind, hopefully not to the detriment of my engine. I wanted to kick it over a few times with the kill button pushed (good suggestion) to get some fuel mix in there and supplement whatever lube was used during the rebuild (to be clear, I didn't do the bottom end and went ahead and had the top end assembled while it was at the shop). Unfortunately, it didn't exactly happen that way.
I didn't put a lot of fuel in it just in case the tank had to come back off. I thought I put the fuel petcock on reserve, but in fact it was in the normal run position. So I kicked it over a bunch of times "dry", with no fuel mix going in.
When I finally got my head out of my rear, it started after a few kicks. It seemed to run very well during a couple break in runs. I've only done a couple heat cycles and haven't really ridden it yet. Right now I am battling a coolant leak, but we are off to do some trail riding at St. Joe State Park in MO later this week. Temps are supposed to be in the upper nineties
So Kirk, I am not much help. I still think the idea to kick it over before starting is a good one. It just didn't work that way for me. I only hope I didn't hurt my motor. Good luck with your startup!
