A question about bar risers.
Fatherof2
Post by Fatherof2 »
Hi Gang,
I just picked up a Scotts damper, and wanted to run some risers as well. I went with the Rox two inch risers, but the damper wont fit under them. Rox sells a one inch extension that will allow the damper to fit. However, I will now be running three inches of riser. I am 5'10'' and have long legs, but everything I have read suggests that guys that are 6'6'' run three inches of rise.
Any thoughts for someone in my situation?
Thanks All,
David
Mr. Wibbens
Post by Mr. Wibbens »
How high does the Scott's sit?
There's 3" between the nut and the bars :?
Fatherof2
Post by Fatherof2 »
Wibbs,
Unfortunately there is a plate that the Scotts sits on that is taking up all the room.
It seems that I have 4 options.
1. Run 3 inches of rise and be able to run the Scotts as well.
2. Run 2 inches of rise and no Scotts.
3. Run no rise at all, but use the Scotts.
4. Order the Scotts riser for 250 bucks and run both.
I guess I have to give the first one a shot, and see how it feels.
3 inches of rise sure seems like a lot on paper.
Wish I had the time today, to really get into it.
Oh well,
Happy 4th!
D.
Mr. Wibbens
Can't you get a sub mount?
guess you could get a W.E.R.
Fatherof2
Post by Fatherof2 »
Well, I tried 3 inches of rise. It is WAY too much.
May have to skip the risers.
rbates9
Post by rbates9 »
If you need a good home for that Scotts dampener I could help you out! :grin:
Fatherof2
Post by Fatherof2 »
rbates9 wrote:If you need a good home for that Scotts dampener I could help you out! :grin:
Thanks rbates, but I think I finally got it sorted. Just going to go with a higher bend. It should help. Can't wait to get it set up. Hope it will be worth the time and money.
rbates9
Post by rbates9 »
Just trying to help! :grin: Good luck!
TWMOODY
Post by TWMOODY »
Fatherof2 wrote:>|<>QBB<
It will be well worth it
