rear shock
rear shock
i think somthing is funky with my rear shock because my bike looks like its sitting low. when i stand back the swing arm is almost flat! any help on how i can fix this?
i have pics but dont know how to upload them
- Mr. Wibbens
When's the last time you serviced it?
- scheckaet
did you set up your sag properly?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
they are used to set your sag by compressing your spring more or less. do a search in the suspension section, you should get the procedure.brayden55 wrote:sag??? is that those spinning rings on top of the spring?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Has thanked: 5 times
- Been thanked: 10 times
It also helps to have the correct rate spring for your weight. Setting the sag might make your bike stick up/squat in the rear with the wrong spring.
- Mr. Wibbens
or more likely your shock is blown , or your spring is sprung
Like Wibby said, "...likely your shock is blown , or your spring is sprung" or maybe someone installed some lowering links. BTW, have you disassembled all the linkage to lube it and inspect it for wear?
- Mr. Wibbens
get a manual and rebuild it yourself, if needed
Get those linkages cleaned and lubed soon. It is one of the few areas on a KDX that does need some regular servicing.
As for fixing it cheap, well, that depends on what is wrong with it. If you don't have the know how on how to diagnose it then I suggest taking it to a reputable suspension guy to take a look at it for you.
i just raised the bike on a lift and tightend the shock a couple more turnes and it seemed to raise the swing arm to the point where it looks normal and feels better. i think i will still need to fix it in time but it should be fine for this weekend
1995 kdx 200 my baby
1986 klr 250
1989 yamaha blaster 200 just like the kdx
1983 kl 250 bought the thing for $100 it wont die
1986 klr 250
