Intake restrictor
Posted: 12:30 am May 02 2020
by Hooters
Hey guys.
Im in the middle of rebuilding the engine and am about to start assembling. Im wondering if anyone else has what looks like a restrictor in the carb side of the reed block. It looks like white plastic wedge with a hole in it. I was just going to remove it and check the results.
Re: Intake restrictor
Posted: 01:21 am May 02 2020
Hi. Which KDX model do you have? Can you post a VIN or engine number? Thanks.
Posted: 01:53 am May 02 2020
by Hooters
Sorry. The bike is a 91 SR.
Posted: 02:36 am May 02 2020
OK, thank you.
Posted: 06:33 am May 02 2020
by kdxsully
Hooters wrote: ā12:30 am May 02 2020
Hey guys.
You could check the parts diagrams on partzilla to see if it comes with it. Not sure if they have the sr model on there. Iād leave it.
Posted: 10:48 am May 02 2020
impex japan for SR model diagrams
Posted: 12:05 am May 03 2020
by Hooters
Thanks for the replys.
I checked the parts diagram and noticed that the reed block is pictured with the "restrictor?" Fitted. There is no part number or explanation of the part. When I get the bike run in I will remove it and see what happens.
Posted: 09:40 pm May 04 2020
by bufftester
It is part of the reed block, and should be there
Posted: 10:11 pm May 04 2020
real wide oval hole?? YES! Leave it!
Posted: 06:45 pm May 06 2020
by Hooters
Thanks guys.
Posted: 07:37 am May 13 2020
by Dan 250sr
Standard carb and manifold... you won't notice any difference in our out
