Intake restrictor
Hooters
Country: Australia
Intake restrictor
Post by Hooters »
Hey guys.
Im in the middle of rebuilding the engine and am about to start assembling. Im wondering if anyone else has what looks like a restrictor in the carb side of the reed block. It looks like white plastic wedge with a hole in it. I was just going to remove it and check the results.
Re: Intake restrictor
Hi. Which KDX model do you have? Can you post a VIN or engine number? Thanks.
Hooters
Country: Australia
Post by Hooters »
Sorry. The bike is a 91 SR.
OK, thank you.
Post by kdxsully »
Hooters wrote: 12:30 am May 02 2020
Hey guys.
You could check the parts diagrams on partzilla to see if it comes with it. Not sure if they have the sr model on there. I’d leave it.
impex japan for SR model diagrams
Hooters
Country: Australia
Post by Hooters »
Thanks for the replys.
I checked the parts diagram and noticed that the reed block is pictured with the "restrictor?" Fitted. There is no part number or explanation of the part. When I get the bike run in I will remove it and see what happens.
It is part of the reed block, and should be there
real wide oval hole?? YES! Leave it!
Hooters
Country: Australia
Post by Hooters »
Thanks guys.👍🏿👍🏿
Dan 250sr
Country: Japanese version
Post by Dan 250sr »
Standard carb and manifold... you won't notice any difference in our out
