What is the max tyre width that everyone runs, standard is 110/90/19 but there is enough room to go out to a 130/90 if my ageing eyes aren’t deceiving me
Rear Tyre
Re: Rear Tyre
Why do you want a tire that wide?? I thought that sounded a bit wide for a KDX200-F3. The Impex Japan microfiche shows a G3 with a 100/90 - 19. You may want to stick with that. Just because it will fit within the swingarm, does not mean it will not ride like a wheelbarrow with a "too wide" rear tire for the stock rim. The 27 year old engine might not be thrilled to try to spin that much weight either.
https://en.impex-jp.com/catalogs/moto/k ... 22799.html
- jstcraig
- Country: Australia
Rear Tyre
It was cheap brand new clear out $50 lol,running a 110/90 was told that was standard size, can’t resist a bargainJason wrote:Why do you want a tire that wide?? I thought that sounded a bit wide for a KDX200-F3. The Impex Japan microfiche shows a G3 with a 100/90 - 19. You may want to stick with that. Just because it will fit within the swingarm, does not mean it will not ride like a wheelbarrow with a "too wide" rear tire for the stock rim. The 27 year old engine might not be thrilled to try to spin that much weight either.
I jst read the bit about the age of the engine that’s a valid point I hadn’t considered, rest assured she won’t be getting an overly hard work out with me on board
Re: Rear Tyre
OK, but what the heck is a "tyre"?
