Fitment issues with 520 O-ring chain?
Ewbarger
Post by Ewbarger »
I am using a new 520 O-ring chain. I was reading on a different forum that the kdx needs a narrow 520 X-ring chain. Anyone else heard this? Anyone have issues with a 520 oring chain eating up the case at counter shaft?
Re: Fitment issues with 520 O-ring chain?
Post by John_S »
I’ve run a couple of different brand 520 o ring chains without issues. I wonder if those 2 orings that sit behind the counter shaft sleeve are worn out causing the front sprocket to have in and out play. The chain on my bike now is a D.I.D 520 oring and it measures 17.8 mm wide at the link and 20 mm wide at the pins.
It is a known issue that some o-ring chains will hit the case on the KDX. That's why x-ring chains are recommended as they give just a little more clearance.
Post by John_S »
That's interesting SS, I haven't heard that. Thank you
Ewbarger
Post by Ewbarger »
Good info, thanks guys! I almost always use D.I.D chains. I found that the D.I.D 520 ervt xring is considered narrow. Going to give it a try.
I've run RK, and even Primary Drive, X-ring chains with plenty of clearance.
Ewbarger
Post by Ewbarger »
SS, 👍. I will be checking my case at front sprocket. Perfect time of the year to do some maintenance and checks!
