New guy with an old led/headlight question
Posted: 10:22 am Jan 14 2020
by mxracercam
Hey all,
Recently picked up a 2000 220R, as it's been a decade or two since I've thrown a leg over a dirtbike and thought a KDX would be a great woods bike to get back into things.
The bike I bought is in great shape, but is missing the headlight and pigtail, and I definitely need lighting. I was thinking of picking up an LED light like this
https://www.amazon.com/gp/product/B00G6 ... 0DER&psc=1 to use in place of a headlight.
I've read posts here where people say I can just wire it directly, I've read ones that say I'll need a diode, rectifier and maybe a capacitor too. Does anyone have any first hand knowledge of bolting something like this in?
Thanks in advance!
-Dave
Re: New guy with an old led/headlight question
Posted: 11:24 am Jan 14 2020
by Goat
I have this no-brand wired directly. Plus added extra grounds thru the tusk kit for street legal hi/lo.
Posted: 11:29 am Jan 14 2020
by mxracercam
Goat wrote: ↑11:24 am Jan 14 2020
Is that an LED?
Posted: 11:36 am Jan 14 2020
by Goat
I’d suspect no diode needed. But haven’t used one of the higher end lights. You’re right I don’t think it is LED. I think it’s is this amazon one (came with bike so not for sure). It says it’s an S2 12V bulb. Sorry not a good comparison for your idea.
Universal Headlight Head Lamp Light Fairing Street Fighter Mask Day Running Light ...
Posted: 11:40 am Jan 14 2020
by mxracercam
Goat wrote: ↑11:36 am Jan 14 2020
Gotcha. How well does that one work for you at night? Thanks for the help!
Posted: 11:55 am Jan 14 2020
by Goat
I am surprised that it seems great. It seems comparable to the headlight on my street bike. I ride it on our woods for perimeter checks and for $20 think it is great.
But we also have used those small LEDs as Jeep pods & on the 4-wheeler and they are brighter.
I better take back my opinion of no diode, as I am not sure if you need one for the LED
My bike has the small (deck of cards) battery for street kit. It lasts forever on LED taillight and blinkers. Not sure how long it would go on small pod.
Posted: 07:48 pm Jan 14 2020
by bufftester
You can run it on AC, but it will flicker at lower RPMs. Several members on here have done just that.
Posted: 04:00 pm Jan 15 2020
by lizardfungus200
Here’s the deal, All led’s including those led pods are meant to run on dc. You could wire it directly, but it would flicker, at the frequency of the ac current the kdx produces. Thats how electricity works, try hooking up an led pod to a battery, it will only light up when current goes one way, and not the other. You dont need a diode, what you need is a rectifier. Diode is for turn signals
Something like this will work. You are looking for a 12 volt, less than 100 watts, and 4 wires: positive and negative in and out real simple
Also, these led pods are rated to 18 watts (mine is) and the kdx produces up to 40, so a resistor would be a good idea to keep the current down and thus temperature down. Those led pods have cooling fins for a reason. You need about an 8 ohm resistor. It will work without a resistor but who knows how long.
https://www.superbrightleds.com/moreinf ... xIEALw_wcB
Posted: 09:10 pm Jan 17 2020
by GOT WOODS?
Lots of good info on this thread:
viewtopic.php?f=115&t=23092
Good luck!
Posted: 01:42 am Jan 21 2020
by bertos883
Some came with a DC rectifier (the aussie '01 for example). i have one of those ebay faceplates with a 12v mr16 downlight globe in it.
Posted: 12:54 pm Feb 07 2020
by mxracercam
Well, I followed Goats advice and went with this setup. It works well and was reasonably easy to install. Thanks brother!
- PicsArt_02-07-12.49.36.jpg (892.09 KiB) Viewed 5726 times
Posted: 02:18 pm Feb 08 2020
by Goat
Nice job! That makes a fair style match. Hope it works good.
I think your brake line routing makes it look even more like it belongs. I had just left mine behind the light so far thinking it might add a little protection. But, now I’m gonna copy off you and add a little pinash before I go trash it, tomorrow.
..... now if I could just come up with the right BNGs.
Posted: 12:34 pm Feb 14 2020
by lizardfungus200
You can also run those led pods on AA or 9 volt batteries
Posted: 03:53 pm Feb 25 2020
by Will0808
My 2001 has the factory headlight? Obviously only works when the bike is on (no battery). Was wondering if I could run an LED bulb in place of the factory halogen?
Guessing my bike has a rectifier?
Posted: 05:08 pm Feb 25 2020
by kdxsully
If you have a regulator/rectifier, I guess it’s just a matter of sourcing the LED.
Posted: 06:03 pm Feb 25 2020
by SS109
Will0808 wrote: ↑03:53 pm Feb 25 2020
If your bike is a standard KDX, as in not an SR version, then from the factory you only have a voltage regulator and not a rectifier.
Posted: 10:37 pm Feb 26 2020
by Will0808
Ah okay. Can I still swap the factory bulb for and LED? Can’t seem to find the bulb size part number
Posted: 10:36 am Feb 27 2020
by SS109
Yes, you can run an LED. All the info on the stock bulb is here:
viewtopic.php?f=77&t=9531
