Crank maintenance specs.
chipper203
Post by chipper203 »
Hi guys, I pulled my top end apart to inspect it and it needs a rebuild. But also there seems to be a lot of play in the connecting rod at the crank. Would anyone happen to know the measurement specs, or where I could find them. (EDIT, see reply below.) Thanks!
Re: Crank maintenance specs.
For the service manual you need to either buy one, or subscribe to Cyclepedia, link is back on the home page somewhere. There can be a little side to side play in the crank, but absolutely no up and down. Rod big end side clearance service limit is 0.70 mm. How do you know you need a top end rebuild without a manual and the specs?
Welcome to kdxrider.net.
The manual is copyrighted, Please don't ask for or post any links to copyright infringement material on kdxrider.net.
chipper203
bufftester wrote: 10:14 pm Aug 20 2019 For the service manual you need to either buy one, or subscribe to Cyclepedia, link is back on the home page somewhere. There can be a little side to side play in the crank, but absolutely no up and down. Rod big end side clearance service limit is 0.70 mm. How do you know you need a top end rebuild without a manual and the specs?
Do you have a link for the service manual? I can’t find it, a link to it would be greatly appreciated. There are scars on the piston and the cylinder, I don’t think I need the book for that part.
chipper203
chipper203 wrote: 06:18 am Aug 21 2019
I was able google and find the book. I purchased it. Thanks
